![]() Drives: 2010 1ssrs Join Date: Apr 2009
ADM Scoop
Is this product worth it
? I have ARH LTs, flow master cat back, rotofab, and a tune.
Adding a scoop will increase air flow to your intake and add some power. For the money and ease of installation it is a pretty good bang for your buck.
IF I have the weak air flow sensor and get a good one along with the scoop, do you think I would really be able to notice something?
Oh and does APEX sell them?
#5 | |
Of course.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
It will give you an extra 4-5 hp but typically speaking, you won't physically notice any difference in hp that is less than a 10 hp change. Meaning your car will be faster with the scoop but you just won't be able to feel it.
Now the difference in going from a weak MAF to a strong MAF is like night and day, scoop or not. |
#7 |
Cool, thanks for the input guys
#8 |
Sorry Chase I have one more question. Were you saying that if I weak sensor and changing it to a new one wouldn't really help since I only have a rotofab on the intake side?
#9 |
What I was saying is that a Roto-Fab alone is not usually enough for the ill effects of a "weak" sensor to start presenting. It usually takes a little more air flow for it to start acting up, like when you add a scoop and/or ported throttle body.
#10 |
ohhh ok I get it! thanks sorry about that
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Yes the scoop is worth the money imo. Look at where your resticted air is coming from now and then imagine a big opening to the lower grille with no water bottle in the way. I no longer run a behind the headlight cai, but if I did there would be another scoop going on at the same time.
She is only memory now. |
#12 | |
5th Gen
Drives: 10 SS Join Date: Jul 2010
#13 |
This may be a stupid question, but is there a lower grill that helps send the air to the scoop? For example does that lower grill with the square openings on right and left side do anything for air flow?
#14 | ||
| Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! | AutoAgenda | V8 Bolt-Ons & Tunes | 438 | 11-23-2013 10:49 PM |
| 2010+ Camaro V6/V8 Roto-Fab Washer Reservoir Relocation Kit & ADM Performance Scoop! | AutoAgenda | Miscellaneous Items | 38 | 07-02-2013 02:12 AM |
| $40.00 OFF Cold Air Inductions Packages! ADM Performance Scoop | Roto-Fab Reservoir! | AutoAgenda | V6 Bolt-Ons & Tunes | 119 | 06-17-2013 12:18 PM |
| 2010+ Camaro V6/V8 Roto-Fab Washer Reservoir Relocation Kit & ADM Performance Scoop! | AutoAgenda | V8 Bolt-Ons & Tunes | 39 | 08-10-2012 01:41 PM |
| SEPTEMBER SPECIAL: $40.00 OFF Cold Air Inductions Packages! ADM Scoop | Roto-Fab Kit! | AutoAgenda | V8 Bolt-Ons & Tunes | 51 | 10-04-2011 09:26 PM |
