Old 01-27-2012, 10:50 PM   #1
Rah17313
Drives: Silver 2010 Camaro RS
Switchback turn signals
I have a 2010 RS Camaro. I purchased a set of switchback turn signals. Once install I could only get the amber turn signals to flash but the driving lights never turned on. I also have load resistors but I'm unsure on how to install them. Can anyone offer assistance or suggestions?
Rah17313 is offline   Reply With Quote
Old 01-28-2012, 12:40 AM   #2
gelboy1015
Drives: '10 2SS/RS, MKIII Supras
The halos are your driving lights. RS Camaro's dont have those "yellow/amber" ones lit up, they're only signal lights.
gelboy1015 is offline   Reply With Quote
Old 01-28-2012, 09:18 AM   #3
Rah17313
I saw a few camaros that have the switchback lights installed.
Old 01-28-2012, 10:38 AM   #4
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
Gelboy is correct. The front turn signals on the RS only work a single filament. You may notice, when you plug the bulb in, theres only two wires coming out of the socket. While driving, they're not on and only flash when signaling. The non RS models use both filaments and are on while driving. Do you know if the ones you saw were RS models? If they were, then they were probably modified. You'd have to run a wire from a running light (halos or side markers) and somehow connect it to the bulb contact that runs the white LEDs.
Unless you are trying these on the tail lights. In which case, I think they should work but the colors may look weird coming out of a red lens.
Saint Alban is offline   Reply With Quote
Old 01-28-2012, 11:56 AM   #5
badazss
SS-500HP
badazss's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Send a message via AIM to badazss Send a message via Yahoo to badazss
Hinthere I have the Led switchback bulbs
What I did was to ad a wire to the connector and ran it to my marker lights they stay white whil I am driving then turn yellow for flashing
Check it out here
http://www.camaro5.com/forums/showpo...9&postcount=17
2ssrs m6 Red jewel tintcoat
Daily Driver 05 silverado ext cab z71
My Build Journal
http://www.camaro5.com/forums/showthread.php?t=103089
badazss is offline   Reply With Quote
Old 01-28-2012, 11:58 AM   #6
Saint Alban
Check it out here
Exactly
Old 01-28-2012, 12:24 PM   #7
Rah17313
Thanks. I just took a second look at the videos I saw and none of the Camaros were RS models. I didn't notice that before. I will modify them to run with the side markers. Thanks for the advice!
Old 01-28-2012, 01:06 PM   #8
badazss
SS-500HP
badazss's Avatar
No problem we are here to help fellow camaro owners
My Build Journal
Old 10-09-2012, 09:55 PM   #9
tomkay
Drives: silver ice metallic 2012 2SS Vert
Hi all , just picked up some switchbacks for my 2012 SS Vert ,i only have 2 wires ,any idea were i can come up with a 3rd to light up my switchbacks
tomkay is offline   Reply With Quote
Old 10-10-2012, 08:59 AM   #10
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Did you read the first 7 posts in this thread? I think #4 and #5 will point you in the right direction...
My VIN = 2G1FK1EJ9A9105017
Eagle Eye Headlights with VLED Turn Signals erk5000 Cosmetics and Lighting Modification Discussions 208 01-22-2014 06:12 AM
Blacked out turn signals and fog lights robg91z Cosmetics and Lighting Modification Discussions 18 10-05-2011 07:45 PM
led turn signals bowtie628 Cosmetics and Lighting Modification Discussions 33 09-20-2011 03:28 AM
Replaced turn signals with chrome dipped cybercoaster Cosmetics and Lighting Modification Discussions 5 08-16-2011 11:05 AM
Door chime and turn signals are loud. zhemel Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 03-14-2010 06:12 AM
