![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS Synergy Green Join Date: Nov 2011
Check engine light after CAI install
All I did today was installed a Volant CAI and used some degreaser and engine shine to clean things up a bit (Was super dusty and dirty)
I bought the Volant used and the seller did not send all of the parts so I called Volant and got all the parts I needed. IN that bag of parts, Volant sent me a new gasket for the MAF. On the phone, the Volant rep said I had to use it. The gasket was ill fitting and I damn near decided to not install it but I did anyway. I drove it for 150 miles then the light came on. I stopped at O'Reilly Auto on the way home and the guy scanned it real quick. It said something to the effect of: Bank 1 lean Bank 2 lean Bank 3 pending Bank 4 lean Could that MAF gasket be causing this? Should I remove it and just mount the MAF to the CAI tube without it? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
There is an air leak somewhere. It's either from the MAF gasket or maybe you didn't get the tube on the Throttle Body good enough.
Re-check everything and make sure it's nice and tight. You can try without the MAF gasket but my guess is you probably need another one. You probably need to call Volant and tell them the gasket didn't fit well and now you're getting a CEL.
Build Journal ![]() |
Firefighter/Paramedic
Drives: RJT 2SS/RS M6 LS-3 Join Date: Aug 2009
P0171 P0174
Recently I dressed up the top of my LS3. I did coil relocators, new valve covers and added the full TechAfx hose kit flipping my fuel rail 180 degrees. I have the Injen full cold air intake with Long tube headers with off road 3 inch full exhaust system. Reading about those codes, it says my car is running lean. People suggest the CAI and Longtubes are the problem. I have had the same CAI and exhaust with longtube headers for 2 years without any codes. Everything is on tight and torqued too spec. Also, I have SC1250 breather kit as well as the catch can. That being said, the vacuum line from the valve cover to the CAI is capped. No other vac lines are loose or off. These codes started after dressing up the engine bay. The car runs great and doesn't have any kind of a missfire. Anybody with any suggestions?
![]() Drives: 2010 2ss m6 Join Date: Aug 2011
It's a vacuum leak, check all fittings especially the tb coupler and filter coupler. Mine threw same code and that's what it was.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
![]() Drives: 2010 2ss/rs black Join Date: Aug 2010
Do you have the dry filter or the oiled filter? I had the same problem when I installed the Volant on my car. I was using the dry filter. I put the oiled filter on and reset the CEL. The problem went away. It's been good for about 1500 miles now.
| Cold air intake/ Check Engine light. Need Help! | edcamaro29 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 64 | 02-17-2024 04:40 PM |
| Update to earlier check engine light question. | Camaro1* | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 09-20-2011 09:23 PM |
| Acronyms at C5 | hokie2012 | 5th Gen Camaro SS LS LT General Discussions | 34 | 08-10-2011 03:56 PM |
| CAI installed (Check engine light on) | LoPerformance Motorsports | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 16 | 08-06-2011 10:19 AM |
| Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 235 | 04-22-2008 12:43 AM |
