Old 02-05-2012, 03:55 PM   #1
5cents
Dave
5cents's Avatar
Drives: 2011 Camaro SS - Black/CGM Stripes
Question Is premium grade gasoline really necessary?
Unless he forgot to mention it, when the saleman was explaining things on my new 2011 Camaro 2SS, he never said anything about using premium gasoline. So, I kept using the "regular" 87 octane. I was reading my owner's manual the other day and in there it recommends "premium" with a 91 or higher octane rating.
My Camaro doesn't "ping or knock" using the lower octane, So, my question is, is the higher octane really necessary?
5cents is offline   Reply With Quote
Old 02-05-2012, 03:58 PM   #2
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Though its not 100% necessary,its highly recommended.
If you do a search there are a few threads on here that discusses the issue,also if you do start running 91+ octane you'll want to do a "fuse pull" to reset the octane table....http://www.camaro5.com/forums/showthread.php?t=38964
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 02-05-2012, 04:00 PM   #3
bill2129
Drives: 2085 Trans AM COBRA
You should always use premium if it calls for it. When I run 87 I lose some mpg and even power. With premium gas I get better mpg and even more pep from the car. The computer will adjust to the premium and give you more timing. I would never run 87 in a high performance engine. Really its only like 1.50more
bill2129 is offline   Reply With Quote
Old 02-05-2012, 04:02 PM   #4
blufin
blufin's Avatar
Drives: Fire Engine
Its not absolutely necessary, but you will get more hp with high octane a d a fuse pull. Why not get all the performance you paid for?
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 02-05-2012, 04:03 PM   #5
bill2129
I can tell if my girlfriend put 87 in my car. You really gotta know your car to feel it
Old 02-05-2012, 04:05 PM   #6
MS3DALE
MS3DALE's Avatar
Originally Posted by bill2129 View Post
With premium gas I get better mpg.
Thats another benefit,my tuner always gets better MPG by tuning for 91+ octane.
When he tunes full-size GM trucks equipped with the 5.3 V8,his customers can usually get 1 to 1.5 better MPG.
Of course he always likes to say..."you probably won't see it because you'll be in the gas more"!!!
Old 02-05-2012, 04:26 PM   #7
VADR_H8R
VADR_H8R's Avatar
Drives: 2011 camaro 1ss synergy green
I read somewhere that the lower octane table is around 10hp lower. So is 10hp worth $3 a tank for premium?
VADR_H8R is offline   Reply With Quote
Old 02-05-2012, 04:34 PM   #8
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I posted the timing tables for each on here and in certain cells it was 7 degrees versus 20 degrees. This is a big difference.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-05-2012, 04:43 PM   #9
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
It's your car put what you want. I personally put premium
Old 02-05-2012, 04:46 PM   #10
Blake_GM
Blake_GM's Avatar
Drives: 2011 Camaro 2SS/RS in IBM
L99 guys running over 6 seconds to 60 on low octane table versus running on the correct high octane table and being able to pull off 5 seconds flat to 60 is a big difference IMO.
2011 Camaro 2SS w/RS, Imperial Blue Metallic - Toy.
CAI Inc. cold air intake, SOLO axle-back with j-pipes, Kooks 1 7/8" long tube headers with Kooks high flow cats, GPI SS2 VVT cam + engine goodies and dyno tuned by Ryan/Dr. L99/GPI.
Blake_GM is offline   Reply With Quote
Old 02-05-2012, 04:55 PM   #11
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Here is how I think about it. Its not that last 30 cents a gallon that will kill you - it's the first 3.00 - 4.00. So lets say you use 500 gallons a year ( about 8,000 - 10,000 miles a year at 16 - 20 mpg) then the premium will cost you about (500 x .30) $150.00 more for the whole year. I'm paying the extra 150.00 and getting all my SS has to offer. Easy math for me.
SSDan is offline   Reply With Quote
Old 02-05-2012, 04:56 PM   #12
Kite31
Kite31's Avatar
Drives: 11' 2SS convertible
At the moment I am using 89.
<img src=http://i14.photobucket.com/albums/a332/spark101/2012-03-26_17-46-01_555.jpg border=0 alt= />
Kite31 is offline   Reply With Quote
Old 02-05-2012, 04:59 PM   #13
RANGERGOD
IDBZ M.C.
RANGERGOD's Avatar
Drives: 12' IOM, 2SS, LS3
I use 93 in everything I own...and after I put the Diablo tune on it, I will have it set for the 93.
RANGERGOD is offline   Reply With Quote
Old 02-05-2012, 05:16 PM   #14
njdad61
njdad61's Avatar
Drives: 2020 Satin Steel 2SS Coupe
The owner's manual says it's necessary in black and white, yet you're still asking? Jesus... Just put the recommended gas in the tank. If you wanted to use 87 and don't care about max performance, you should have bought a V6. If you can't afford to put the right fuel in it, then you can't afford the car.
  • TPW 8/5/19
  • Built 8/2/19
  • Arrived 8/13/19
  • Home 8/16/19
njdad61 is offline   Reply With Quote
use premium gasoline after twice regular gasoline essa 5th Gen Camaro SS LS LT General Discussions 28 07-16-2011 10:57 AM
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
100 Octane cody.freeman1 5th Gen Camaro SS LS LT General Discussions 36 03-25-2011 11:00 PM
Gasoline: Premium or Plus? perfxn 5th Gen Camaro SS LS LT General Discussions 27 05-26-2009 12:51 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
