Old 02-07-2012, 04:36 PM   #1
sullivang
Drives: 69 vette
6.2 SS OIL CONSUMPTION-PLEASE READ
Hello, Its been a while since I have been on here but I wanted to see if I can get some feedback on this oil consumption issue with the 6.2. I have a really good reason for asking but I would like to get as much feedback as possible before I give out the troubling details.
Do you think that GM would issue a recall if a lot of the 6.2 engines are burning oil?
What do you think it would take for GM to rebuild or put in a new engine that is burning oil?
Would a new Camaro thats burning oil pass a CA smog check?
Where do you think the oil goes?
Are there many people out there that the engines are burning oil?
Hope to hear from you guys soon
NPCTM2
1100, Preliminary order accepted - 08/25/09
2000, Order accepted by GM - 09/15/09
2500, Order preferenced - 09/30/09
3000, Order accepted - 09/30/09
TPW - 10/26/09
3300, Scheduled for production - 10/13/09
3400, Order broadcast - 10/19/09
3800, Order produced VIN 2G1FS1EW7A9160044-10/27/09
4000, Availiable to ship 10/28/09
4200, Shipped 10/29/09 ETTX904551
5000, Delivered to the dealer
6000, Delivered to the customer
sullivang is offline   Reply With Quote
Old 02-07-2012, 04:38 PM   #2
Dznts
Anabolic Connoisseur
Dznts's Avatar
try here
http://www.camaro5.com/forums/forumdisplay.php?f=70
Old 02-07-2012, 04:41 PM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I've heard about it with the V6s but not the V8s.
Are you sure it's 'Burning' oil? Lot's of them had oil leaks at the pan. Small leaks that over 8k miles would lead to the car being low.
I've not heard of a common problem for the LS engines burning oil.
Old 02-07-2012, 04:45 PM   #4
HDRDTD
Burning how much oil how often. It's all relative.
I've got close to 13K miles on my 2SS/RS M6 and haven't had any oil issues at all.
Old 02-07-2012, 04:50 PM   #5
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
They will not issue a recall. They haven't for the convertible top problems yet. The best we will get is a TSB and hush hush from them about any problem.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 02-07-2012, 04:57 PM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
http://www.camaro5.com/forums/showth...ghlight=excess
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-07-2012, 05:05 PM   #7
MIKnam67
MIC
Drives: 2012 SSRS 6sp man Blk
Smile
I have a 2012 SS with 2400 miles and just checked yesterday. Dipstick at full mark.
MIKnam67 is offline   Reply With Quote
Old 02-07-2012, 05:07 PM   #8
PQ
Booooosted.
PQ's Avatar
Originally Posted by IndeedSS1 View Post
Yup, I remember reading that.
Old 02-07-2012, 05:11 PM   #9
SC2150
Never. The issue I see when tearing these down is the rings never properly seating since syn is used from the factory. We break all in with a good conventional. The second problem is they are driven easy during the breakin period....the motor needs to be driven hard & fast to seat the rings properly and then the break-in oil changed out for full syn after app 100 miles or less.
They may re-ring after a documented oil consumption test is completed...
The cats should burn most if not all the hydrocarbons so I expect yes, but am not 100% sure.
Is burned. Most due to the useage past the rings but a good amount through the PCV system. You may have a faulty baffel/orfice in the valley cover allowing excess oil drawn into the intake aircharge. A GOOD (not a poor functioning) oil separating catchcan will catch it before ingestion and save fuel & prolong engine life.
Below are pictures of what I am refering to:
and what this does to your pistons:
Your not alone, this is a problem with most newer cars & light trucks...not just GM.
Lots, but to variying degrees and plenty that dont use it.
Old 02-07-2012, 05:41 PM   #10
sullivang
Drives: 69 vette
Nice pictures! Is the engine from a Camaro? I heard that before about rings not seating. Would you consider "sticking rings" to be that same thing?
From the pictures, it looks like you may have been working on that engine?? Were the pistons replaced?
NPCTM2
TPW - 10/26/09
Old 02-07-2012, 05:43 PM   #11
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
CATCH CANS need to be FACTORY INSTALLED. when you change the oil just pour out the 1 quart of oil that ends up in the catch can and not on top of the pistons.
2001ragtop is offline   Reply With Quote
Old 02-07-2012, 05:50 PM   #12
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
what sc2150 said
The LS1 burned oil, the LS2 burned oil, so does the LS3. This is mostly with manuals and mostly with drivers that don't rev match perfectly. A little oil escapes past the rings each time. That's the whole reason people put on catch cans.
VTXrider is offline   Reply With Quote
Old 02-07-2012, 05:58 PM   #13
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
My CC has caught about 15oz in 2500 miles; I've gotta empty my CC every 500 miles. I think my problem is similar to IndeedSS1; leaking Valley Cover.
GM wants me to document oil consumption by removing the CC, putting the
OEM PCV tube back, get an oil change and come in every 1000 miles for a check up (at a Dealer)
RiCorvette is offline   Reply With Quote
Old 02-07-2012, 06:01 PM   #14
RiCorvette
RiCorvette's Avatar
Originally Posted by VTXrider View Post
VTXrider?!?! No Way! Me too!
07 1300R
Not the only reason for CCs; Check out IndeedSS1 and my posts.
I'm glad I have one; 15 oz of oil in 2500 miles is a lot!!
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
