Old 02-08-2012, 03:24 PM   #1
DARKANGELCAMARO
DARKANGELCAMARO's Avatar
Drives: 2018 ZL1, 10L90E
5" intake tube installed
I replaced the stock 4" plastic with 5" polished aluminum. I will post the details of the parts to do this later, if anyone's interested. The LS3 definitely likes the big gulp of air. Slight increase in response noticed.
2018 Denali HD L5P, A6
2018 Camaro ZL1, A10
2006 Corvette Z06, M6
(YouTube channel name-ANGRY6LITER for videos)
DARKANGELCAMARO is offline   Reply With Quote
Old 02-08-2012, 03:26 PM   #2
Nice, that looks awesome
Old 02-08-2012, 04:21 PM   #3
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Does the 5" intake tube look cool, of course it does. Trust me, I am not trying to rain on your parade here or even try to convince you to buy our CAI, I am just offering some food for thought because I live and breathe this stuff for a living. One BIG problem that I am seeing is that you are going to be sucking hot air into the engine. The IAT is much more relevant to making power than the volume of air you are bringing in when it comes to what you have set-up N/A. If you want do have a DIY kit (although I dont reccoment it) I would at least consider doing a heat shield of some sort to block off some of that engine bay heat. Just something to consider.
Sales @ CAI Inc is offline   Reply With Quote
Old 02-09-2012, 12:07 PM   #4
DARKANGELCAMARO
Here are the part numbers, vendors and prices...
www.SFXPERFORMANCE.com
Spectre 5 Inch Mandrel 110deg Elbow With 6 Inch Leg - P/N: SPT96962 - $78
(But you might want to go with 120 degree bend - P/N: SPT96963)
Spectre Vacuum Sensor Adapter kit – P/N: SPT9712 - $8
www.EBAY.com
Ebay Store: Mandrel Bending Solutions
5" to 4" Gray 5 ply Silicone reducer coupler - Item #310371111356 - $30 for 2
www.HPS-SILCONEHOSES.com
HPS Stainless Steel T-Bolt Clamp 5.24" - 5.55" for 5" inch hose - SSTC-133-141 - $12 for 2
HPS Stainless Steel T-Bolt Clamp 4.26" - 4.57" for 4" inch hose - SSTC-108-116 - $12 for 2
ADVANCE AUTO PARTS
3/8” fuel line hose - $10
(2) 5/8” fuel line hose clamps - $4
Cut off 1” from short end of aluminum tube and 5.5” from the long end. Drill a ¾” hole for the grommet and adapter for the “valve cover-to-intake” hose. I cut down the bottom half of the factory airbox (keeping the cold air duct installed) to shield the filter from some of the heat and let cool air flow in. I do plan on fabbing up a heat shield. I will follow up with pics when that is complete.
Old 02-21-2012, 07:40 PM   #5
DARKANGELCAMARO
Some follow up pics... As you can see, with the factory fresh air intake tube connected to the modified factory lower airbox, the filter gets cool air for the most part. It is shielded from header heat, and the massive 5" intake tube allows for a large volume of air to be readily available for when you stomp the throttle.
Old 02-21-2012, 08:18 PM   #6
bersterman
bersterman's Avatar
Drives: 2012 2SS/RS M6
Street Scenes billet grille (upper and lower)
Cold Air Inductions intake w/MPD gasket/seal kit
MPD cowl induction hood
RX Catch can
Edelbrock shorty headers
MSD wires
Custom cat-back w/GMPP exhaust
Hurst short-throw shifter
GMPP splitter and high wing spoiler
Lloyd's custom "SS" mats
Showstopper under hood accessories
bersterman is offline   Reply With Quote
Old 02-21-2012, 09:22 PM   #7
honeybucket99
Drives: 2SS/RS CGM CAMARO BEAST
how are you getting more air? Can the 5" flow more that the stock restriction at the filter box or the opening restriction of the Throttle Body?
Intuitively, it seems to me, with the increaser then decreaser you have, you are going to lose air flow velocity and create turbulence which will mess you up.
2010 CGM 2SS/RS; 418 stroker; JE Forged Pistons (offset wrist pin); Forged Crank; upgraded valvetrain; Custom Comp Cams Cam; Kenne Bell 2.8; ID 1000s; Aeromotive Fuel pump with return; ARH Long Tubes; Spec heavy duty clutch; 3" Magnaflow Cat Back; Nick Williams 102 mm Throttle Body; Tune fixed by Dave Steck; 815 HP and 14 mpg
Upcoming--
Disintegrated drivetrain;
Divorce if/when my wife catches on to
my addiction
honeybucket99 is offline   Reply With Quote
Old 02-21-2012, 09:30 PM   #8
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
A more normal sized/smaller tube will pressurize the intake air more allowing for a denser charge. Same reason a bigger exhaust is not better.
MarylandSpeed is offline   Reply With Quote
Old 02-21-2012, 11:03 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
Question: Where's your MAF sensor?
Click to view my build thread
Old 02-22-2012, 12:02 AM   #10
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
looks good man, just cause you didn't spend 400 bucks on an intake system doesn't mean it's not going to perform. i applaud you for your creativity, and i'll say it, an intakes an intake.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
Old 02-22-2012, 01:17 AM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Dyno test!
SUX2BU is offline   Reply With Quote
Old 02-22-2012, 10:15 AM   #12
DARKANGELCAMARO
Yes the 5" tube will flow more air than the stock 4". Plus it will "contain" more air (volume). The tube I installed does not have chambers or the accordion style connector, thereby eliminating all the turbulence that the stock tube created. The silicone adapters I used are tapered so the airflow still remains smooth.
Old 02-22-2012, 10:18 AM   #13
DARKANGELCAMARO
It is still there. The connector is rotated to the rear out of view of the pics. It is what the air filter is attached to.
Old 02-22-2012, 10:18 AM   #14
DARKANGELCAMARO
Thanks!
Injen Short Ram Intake Installed sdmaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 07-19-2011 09:09 AM
Breath clean Air GmPartsDirect.com Interior Parts & Accessories 0 03-30-2011 05:58 PM
Help You and Your Ride Breath Easier GmPartsDirect.com V8 Bolt-Ons & Tunes 0 03-30-2011 05:49 PM
I F#@^up! Think I need a new intake tube for my Roto-fab CAI King T Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 04-12-2010 11:52 PM
