Old 02-11-2012, 10:59 PM   #1
SSTG
Drives: 2014 Z51 Corvette
M17 Modulare Forged.
Does anyone have a pic of the M17 on their Camaro?
SSTG is offline   Reply With Quote
Old 02-12-2012, 05:41 PM   #2
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Just an fyi, these wheels are expensive and a pain in the ass to get mounted, as most tire stores can't do them without messing up the center bead....I speak from experience...
So Cal Camaro is offline   Reply With Quote
Old 02-12-2012, 06:25 PM   #3
SSTG
Really? First I've heard of that.
What is the issue exactly?
Old 02-12-2012, 06:34 PM   #4
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Basically same issue with any 3 piece wheel, they have a bead of silicone in between the two halves of the wheels, getting the rubber onto or off of the wheels is a pain given the wheel design, even the tire guys that know how to do it takes a lot of time. When they are trying to get the tire on or off, if they hit that bead with a tire iron, it will leak, which is an issue I had from when I first put these wheels on, they had a slow leak in two, exacerbated greatly by Tire Rack when I had to change tires while on the Power Tour....If I had it to do over again, I would avoid 3 pc wheels and just spend a little more for HRE wheels...or COR mono blocks...make up your own mind, just sharing my experience...
Old 02-12-2012, 06:37 PM   #5
SSTG
I appreciate it. But it can't be that bad or no one would buy them right?
Man I hope you are an isolated case!
Old 02-12-2012, 07:04 PM   #6
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Good luck....
Old 02-12-2012, 07:07 PM   #7
SSTG
Thanks, but for 6000 I better not need luck!
Old 02-12-2012, 07:09 PM   #8
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
I would go the tire store you plan to have install them and ask if they work on 3 pc wheels...and then ask how much they want to mount them...
Old 02-12-2012, 08:55 PM   #9
SSTG
Thanks, I am gonna try and buy them already mounted from the Vendor.
Different Wheel Construction Types Explained Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 45 12-21-2017 08:37 PM
Wheel Specialists, Inc. - Proud distributor of Modulare Forged Wheels Sean@WSIAZ Wheels / Tires 25 05-02-2012 03:30 PM
360 Forged, System Forged, Modular Concept Nine Ball Wheels / Tires 0 03-08-2011 08:19 AM
New Modulare Forged B15 wheels Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 14 08-25-2010 08:12 AM
