Old 02-12-2012, 12:15 AM   #1
Peter-5
Peter-5's Avatar
Drives: 2010 Camaro V6 turbo
TAPshift problems on my camaro
When I go to shift up when I try to us it. It wont shift. does anyone one have an idea. I put LT heads on the car and the engine light came on and i know its the o2 sensor but could it not be shifting because the CEL is on?
Peter-5 is offline   Reply With Quote
Old 02-12-2012, 10:39 AM   #2
kgilley09
kgilley09's Avatar
Drives: 99 Silverado
Did you put it in M or whatever the sport mode is called rather than just leaving it in drive? If so, I really don't know what the issue would be, I wouldn't think that the CEL would be causing the issue personally.
kgilley09 is offline   Reply With Quote
Old 02-12-2012, 12:42 PM   #3
Peter-5
Peter-5's Avatar
yea I put it in M and nothing! I talked to Chevy and the guy said when your engine lights on usually tap shift and cruise control doesn't work but everything does work CC is fine its just the tap shift. I can even shift down just not up.
Old 02-12-2012, 12:44 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Can you get the code cleared out and see if it works then?
Old 02-12-2012, 12:58 PM   #5
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Can you rephrase the question... In English?
Old 02-12-2012, 01:05 PM   #6
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
Bro I had this problem only when I broke the clock spring in the steering wheel...You probably disconnected the steering column and turned it to many times which broke the clock spring...Its a little sensor...Take it to the dealership it a easy fix... Next time tie the steering wheel up where it doesnt move at all and you will not have this problem! Once this is fixed tapshift will work again. Good Luck! I think they charged me like $170 to fix!!! Your CEL is on because the car is running Lean until its tunes!!!
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 02-12-2012, 01:06 PM   #7
Revo1
Drives: 2010 2SS/RS
Originally Posted by 1985airborne View Post
Bro I had this problem only when I broke the clock springh in the steering wheel...You probably disconnected the steering column and turned it to many times which broke the clock spring...Its a little sensor...Take it to the dealership it a easy fix... Next time tie the steering wheel up where it doesnt move at all and you will not have this problem! Once this is fixed tapshift will work again and your headers will open that L99 up and you wont be disappointed! Good Luck! I think they charged me like $170 to fix!!!
It's an LLT. Sorry, done trollin.
Old 02-12-2012, 01:07 PM   #8
1985airborne
One Slow Automatic
I was correcting my statement as u posted...
Old 02-13-2012, 01:29 AM   #9
Peter-5
Peter-5's Avatar
Darth_Emma the only way to clear the code is to get a tune i think but i dont have one /:
and 1985airborne what do u mean keep the steering wheel tied up? and thanks for the help guys!
Old 02-13-2012, 03:06 AM   #10
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
If the engine light is on it won't work! Also the remote start wont work! Get a tune!
dshep214 is offline   Reply With Quote
Old 02-13-2012, 06:37 PM   #11
Peter-5
Peter-5's Avatar
dshep214 the guy at chevy also told me that cruise control would not work and it does!
Old 02-13-2012, 06:48 PM   #12
Darth_Emma
Darth_Emma's Avatar
You definitely need a tune. You'll love it.
Come over to the dark side.
Old 02-13-2012, 08:18 PM   #13
Peter-5
Peter-5's Avatar
haha ok i gotta save up first!
problems, tapshift
Automobile Reviews 2011 Chevrolet Camaro Convertible 2SS Tran Camaro Convertible Forum 33 07-28-2011 08:36 PM
