Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
Weapon-R Intake for V6 camaro?
If you have dealt with imports before than you probably know or heard about weapon-R, well, it look like weapon R has intakes available for the V6 and V8 camaro. It has a 2 pipe design that supposed to increase velocity and volume of air going in, at least they say
It also come with polyeurethane foam filter that supposed to flow 3x more then the conventional cotton high flow filter such as K&N. I don see any dyno numbers or expected gains anywhere. Anyone have any more info on this intake? The Secret Weapon Intake was designed to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other, which a) increases air volume and speed to the engine and b) feeds the engine 3x more air than a conventional air intake system! If you want to upgrade your performance, an After Market Intake is one of the First Things You Should Upgrade When Modifying Your Car My intake systems come with a Secret Weapon Air Filter, which has re-usable, high density, open pore foam to minimize turbulence and give you even more performance. Performans better than any other filter available on the market today. Warranty included, 1 million miles. The intake comes with everything you need for installation! All adapters. All fittings. Everything you need to place your existing mass air flow sensor (MAF). Your engine light will not come on. These products aren't cheap, they are made of 6061 Aluminum, CNC Mandrel Bent, and then TIG Welded to make a super tight seal and proper fit. They are made in the USA and polished to show a high quality finish. The Weapon-R Secret Weapon Intake includes: Our Weapon-R Secret Weapon Air Intake 6061 Aluminum CNC Mandrel Bent Intake Tubing with Polished finish Pure Silicone Hoses & Couplers Stainless Steel Clamps Weapon-R High Flow Secret Weapon Performance Air Filter Intake Bracket & Screw-in Vibration Mount Weapon-R Stickers & Catalogs Any applicable items included in the current special Need more eye candy? Check out the Dyno Test Videos or the Weapon-R Promo Video How it works Here are some pictures of a flow test done with our specially designed flow bench. Our flow bench is very similar to those used to test flow in machine shops. We measure pressure, in this case vacuum pressure, inside of the pipe. The form of measurement we use is in H2O, or inches of water. This is the same as a majority of industry flow benches. Almost all flow benches use a meter called a Manometer, which has actual water in it, to make its measurements. We opted for a more precise method, using a precision tuned digital vacuum meter, provided to us by The DigiVac Company. The easiest to read this is the higher the number on the display, the better the flow is through the pipe. All test shown were performed using a Craftsman 5hp wet/dry vacuum as a vacuum source. Picture 1 : Picture of the PATENTED " Secret Weapon Intake Pipe " design. You can see the smaller inner tube used to increase velocity. The airflow through the inner tube has a higher velocity than a standard 3" intake pipe. The higher velocity / volume of airflow from the inner pipe creates a low-pressure vacuum at the throttle body end of the pipe, called a Venturi. This Venturi draws the air from the outer pipe, increasing its velocity, and increasing the overall volume of air entering the engine. Picture 2 :In this picture, we first test a standard 3" pipe. Here you can see that the display is reading 1.4 in H20. We cap off the other pipe to provide a more accurate reading. Picture 3 : In this picture we are now testing the Secret Weapon design. We see that the reading has increased to 2.3 in H20. This increase is due to the small inner pipe increasing velocity in the intake tract. Picture 4 : In this photo, we test a pretty good-sized K&N style gauze filter. You can see that with this filter, the reading has actually DECREASED down to 2.0 in H2O. Picture 5 : Swapping a Secret Weapon filter for the gauze filter, shows a large increase over the gauze filter and over just the open pipe as well. The improved velocity stack and filter design encourages the air to flow in a direct route through the pipe while maintaining a high velocity and low restriction. What does this all mean? The Secret Weapon uses two important laws of physics to increase airflow. The first law is Boyles law. This law basically states that as air velocity increases, its volume increases as well, while the pressure decreases. The second law is the Bernoulli Equation, where a moving fluid (in this case air) has a lower pressure than air that is standing still, or is moving slowly. This same law is used in NASCAR for both downforce and "drafting." When we increase the air velocity in the intake, we create a low pressure area that draws a higher volume of air than a standard intake would. In layman's terms, we are creating a vacuum effect using natural laws of physics. Do the Weapon-R Air Filters, filter dirt better than K&N / AEM / Injen Air Filters? The Secret Weapon Air Filter is made of Polyeurethane Foam, which is rated at 300 Pores per square inch. Whereas the K&N / AEM / INJEN air filters are rated at 30-60 pores per square inch. This means that there are more dirt particles passing through the air filter to the engine when using their filters. Why is the Secret Weapon Air Filter so much better? The reason why the Secret Weapon Air Filter flows much better than any other filter on the market today is because of the specially designed Velocity Stack inside the air filter, it helps gather more air into the air filter and reduces the turbulence of the air into the intake tube. |
We need an engineer to tell us if any of that checks out. I'm certainly not smart enough to know.
[B]
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Interesting, but not sure I'm convinced of anything here.
First off, unless the Camaro V6 version has a heat shield...then thats a bit of a downer. 2nd...even though air in the smaller tube is moving faster...I don't think that necessarily means it is feeding more air. Kind've like cars moving down a 2 lane highway versus a 4 lane. the 4 lane can be less crowded but still move the same or more amount of cars. But I'd still be very interested to see what this thing can do.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
that is interesting. i ran across that a few days ago online too. anyone find a dyno sheet or anything?
Well.. I just emailed weapon-R and asked for more info and dyno so let's see what we get in the reply. I wonder why no heat shield. That is kind of dissapointing. If it does flow more air then does that mean more hot air? LOL.
#6 | |
Any airflow experts care to chime in if this is a theory that can actually work or just a marketing stunt? Again, why no heat shield
#7 |
Dr.Frankenstein
i dont know about this seem like that ol ricer marketing were you put a bunch of hot girls Hold your intake saying it will make Big Power ... And She likes Big Power LOL
#8 |
![]() Drives: 2011 1LT M6 Join Date: Dec 2011
I'll take two!
#9 |
#10 |
Slow v6
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes USAF. Stationed in TX |
#11 |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
What's the price of the Weapon-R intake? I just wish a company would come out with an intake for the v6 in the $150 range.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
#12 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Basically it creates a Venturi effect... I was very skeptical about the AeroTurbine mufflers, but we put one on my V6 muffler and we seen like a 10 HP gain over the Magnaflow I had on it... so yes, the Venturi effect is real and beneficial in a muffler... now, is it effective in an intake???
#13 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Dyno tests will show....lets get some and see. The heat issue is real for sure, but I can say yeah or nay w/out testing. Has my interest though!
#14 |
I'm certain if this indeed work then building a heat shield wont be an issue. anyone care to donate this intake for testing LOL
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 01:25 PM |
| SEMA Show 2010 - New Camaro Products Showcase - pictures & descriptions! | Sean@Phastek | Camaro Photos | Spyshots | Video | Media Gallery | 59 | 06-23-2011 01:56 PM |
| Modern Camaro Performance Parts - www.PartsTaxi.com | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 10-06-2010 05:26 PM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 08:33 PM |
