Old 02-22-2012, 08:14 PM   #1
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
For Sale: Patriot Gold Double Spring Kit .650 Lift!!
I'm selling this kit because I have decided to go with a COMP Cams double spring setup for my more aggressive camshaft. My lose is your gain because I'm looking to make a deal here. PM me if your interested in buying the kit. Everything is new and has never been used before. I accept Paypal. This kit sells normally for $265 + shipping. So please make me a REASONABLE offer. DON'T ask what is the lowest I'm willing to sell this kit for ... just make me a reasonable offer and I will get back to you promptly. Thanks for looking and feel free to ask questions! I will sell for $225 no questions asked shipped anywhere!
Patriot Performance's legendary Gold spring kit is probably the most used "drop-in" LS dual spring kit in the LS community. These complete spring consists of 16 Patriot Gold dual springs, 16 titanium retainers, 32 Super 7 Machined locks, 16 .505" ID machined spring bases, and 16 viton rubber seals. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed.
I'm also selling BRAND NEW STOCK LS3 valves!!
Intake valves Part Number #12569427
Valve size: 2.165"
Stem size: 8mm
Description: Stock replacement hollow stem valve used in LS3 engines
Exhaust Valves Part Number #12582719
LS Series Exhaust Valve. 1.59"" with a 8mm stem size. Stock replacement solid stem valve used in L76, L92 and LS3 engines.
I'll sell the Spring Kit with the fresh new valves for $450 OBO. Thanks!!
Also if anyone is interested in Mid-April I will have my stock used LS3 Lifters, Pushrods, Timing Chain/Gear, and Camshaft Available! If your interested in these parts please offer a price. I'm looking to selling those parts as well. Thanks!
Technical Specs:
Install Height: 1.800"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.150"
Coil Bind: 1.090"
Retainer Material: Titanium
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
Old 02-23-2012, 11:08 PM   #2
ztsmith86
ztsmith86's Avatar
Bump
Old 02-25-2012, 09:18 PM   #3
ztsmith86
ztsmith86's Avatar
Spring Kit sold!!
Valves are still for sale!! $250 OBO!!
Old 03-07-2012, 12:04 PM   #4
ztsmith86
ztsmith86's Avatar
Sold
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 10:31 PM
Eibach vs. BMR KybheSS Suspension / Brakes / Chassis 24 01-13-2011 06:15 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
