Old 02-25-2012, 09:29 PM   #1
mickymaro69
mickymaro69's Avatar
Drives: ls3
oil pan leaks
What methods have those of you used to fix the oil pan leak problem with the 6.2 engines? A buddy of mine took his to dealership and got it back still leaking and this happened to me as well.
mickymaro69 is offline   Reply With Quote
Old 02-25-2012, 09:48 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
To do it right you need to replace the seal, and that is really hard with the engine in the car
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 02-25-2012, 10:55 PM   #3
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
Mine leaks to, i'm just to lazy to take it to the ler. I'm surprised that the dealer didn't fix it right, maybey there's an underlying issue.
2010 RS2SS, XS POWER HEADERS AND FULL EXHAUST, ROTOFAB COLD AIR AND ENGINE COVERS, MSD PLUG WIRES. PFADT DROP SPRINGS, SPORT SWAY BARS, TRAILING ARMS, TOE LINKS. HURST SHIFTER, BILLET PEDALS.
BLACKOUT TAIL PANEL, TINTED TAIL LIGHTS, MAIL SLOT BLACKOUT, WHITE BOWTIES
greenmachinedriver is offline   Reply With Quote
Old 02-25-2012, 11:26 PM   #4
mickymaro69
Drives: ls3
Yeah I'm real disappointed in my dealership. My neighbor suggested just applying a bead of silicon gasket goo on the outside area where it is leaking from. Anybody think this might work?
Old 02-26-2012, 09:38 AM   #5
MikeOD
Drives: 2010 M6 2SS
Please don't do that. I've taken apart a few older engines that someone did that too to try to stop leaks of some sort...the engines still leaked, and it just made it a nightmare to work on the engines and get them cleaned up.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 02-26-2012, 10:05 AM   #6
mickymaro69
Drives: ls3
man i still can't get over the fact i'm considering pullin' the engine on a new car with 5800 miles on the odo!
Old 02-26-2012, 10:28 AM   #7
MikeOD
Drives: 2010 M6 2SS
You don't need to pull the engine to replace the oil pan gasket.
It's NOT an easy job, but it can be done with the engine in the car.
Old 02-26-2012, 10:53 AM   #8
mickymaro69
Drives: ls3
which would you say would be the MOST difficult aspects of it?
Old 02-26-2012, 12:08 PM   #9
Parag
The brace is right below the pan, so you cannot remove the pan more than 2 inches. And nothing is a striaght shot. A five min job with engine out. Turns into a 2 hour job. But it would take easy 2 hours to get the engine out, so it is better to fight it. Make sure the seal is in striaght, really easy to get wrong since you cant see anything
461 RWHP, 422 RWTQ
Old 03-21-2012, 05:15 PM   #10
010 Camaro SS
010 Camaro SS's Avatar
Drives: 2010 Camaro SS 2SS
Dropped mine off today "oil Leak"...Oil pan gasket...They said
8 hours to change (GM Notes)...He says his mechanic will do it in
4 hours...Has done a few...Will see when i pick it up tomorrow...
010 Camaro SS is offline   Reply With Quote
Old 03-21-2012, 06:49 PM   #11
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I lifted the engine with a cherry picker and lowered the k-member a bit. I still couldn't get the oil pan off, but it was down far enough to slide the gasket around the oil pick up. The Whipple made it where I couldn't lift the engine as much as those with a stock intake. If you still have a warranty, I would let the dealer do it. If you do it yourself, don't forget to apply rtv at the corners where it meets the front and rear covers.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 03-21-2012, 08:00 PM   #12
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
Dropped mine off on Monday for "oil leak", got a call the same day saying it was the oil cooler that was leaking. They replaced it. Have not picked it up yet, so i can't verify if there is no more leak.
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
BigBlue2010 is offline   Reply With Quote
Old 03-21-2012, 08:31 PM   #13
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
Took my dealer less than 4 hours to replace my oil pan gasket. No more leaks!
ITGuy11 is offline   Reply With Quote
Old 03-23-2012, 09:25 PM   #14
mickymaro69
Drives: ls3
thanks for sharing info. keep us posted please and thanks again.
How to change your oil in V6 trooper182 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 20 12-16-2012 07:08 AM
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 07:50 AM
