Old 03-02-2012, 01:38 AM   #1
1baer
Drives: Camaro 2SS / RS
RAP does not work correctly with Metra-Kit
i have installed a kenwood ddin-radio with the metra kit about a year ago.
when i turn off the ignition the radio stays on like it should, but after about 20 sec the radio shuts off with a loud cracking noise from the speakers.
the same happens if i take out the key immidiately. as far as i know, the radio should shut off immediately after taking the key out of the lock and not stay on.
if working correctly, the radio should stay on for 10min if you do not open the door or take the key out of the lock.
i think this problem exists from the beginning but i never realized it.
does anyone have an idea why this happens?
1baer is offline   Reply With Quote
Old 03-02-2012, 10:30 AM   #2
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I do not know about the loud cracking noise when it shuts off. The radio staying after will stay on ofter the key is removed is a normal for the Camaro. The radio will stay on for 8 mins after the key is removed or when the drive side door is opened.
Caddy
Caddyroger is offline   Reply With Quote
Old 03-02-2012, 11:36 AM   #3
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
the cracking noise souns like you need to get rid of the 6v floating ground that is in the head unit when you get a new amp. If you did get a new amp get a ground loop isolator. Did you get a new amp?
caddyroger is correct about how the radio should stay on. If your opening the driver side it will turn off immediately.
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 03-02-2012, 12:39 PM   #4
Genious
Army EOD Tech
Genious's Avatar
Drives: 2010 Camaro SS
i just ordered a metra kit for a complete audio upgrade im planning on doing this week, i have never heard of a GLI is there a spcific kind we should have for this car, or will anyone do.
Genious is offline   Reply With Quote
Old 03-02-2012, 04:04 PM   #5
camarograna2
Car Enthusiast
note some amps are ok with the voltage coming from head unit so you may not need it. I originally got ********s kit to add subwoofers to my stock radio kit and i knew right away i needed it because of the cracking noise. So just go buy one that day and keep the receipt. you may not need it.
Old 03-02-2012, 04:59 PM   #6
Genious
Army EOD Tech
Genious's Avatar
Where to you put it coming off the head unit or just before the amp, or does it matter
Old 03-02-2012, 06:13 PM   #7
camarograna2
Car Enthusiast
That I dunno. Unfortunately I can tell you how to create some business processes but not how to install. Had my installer do everything for me but new the stuff up to here from experience.
Can you audio guys help further
Old 03-03-2012, 05:27 PM   #8
Genious
Army EOD Tech
Genious's Avatar
Any of you audio guys know the exact placement of the ground loop insulator
Metra Kit and Seat Belt Chime Problem 1baer Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 01-18-2012 03:01 PM
Metra Dash kit button color vlavaRS Audio / Visual / Electronics/ Gauges / Nav 1 09-08-2011 07:16 AM
Metra Kit Issue? phenixdragon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 07-18-2010 01:42 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 01:07 AM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 12:19 PM
