![]() Drives: 2SS Black w/ Inferno Orange Stripes Join Date: Sep 2010
2 year old, do I need an oil change after storage?
I am preparing to take my car out of the garage for spring and am wondering if I should get the oil changed. I had it done before and after winter last year to get all the crap that may be left from production. Now that it is 2 years old and has had a couple changes is it necessary to change again in the spring? I have 78% oil life left and feel its a waste of $80 if its unnecessary.
I tried the search and only found threads from 2010. If someone could point me in another direction that would be great! Thanks
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
She is only memory now. |
![]() ![]() ![]() Drives: IOM 2010 - 2SS/RS Join Date: Nov 2008
I always change mine after storage, if nothing else then piece of mind.
2010 2SS/RS IOM Upgrades: Fastlane CAI / SLP II Loudmouth axle back / V Max Ported TB / Kook's Step Long Tube Headers / High flow cats / Straightline Tune / BMR front & rear sway bars / Hotchkin End Links / Hurst Short Throw. LG ZR28 Wheels 1 of 2 sets made. Pfadt trailing arms / Diff Bushings & Sub Frame bushings / 1LE Axle & Hubs.
![]() ![]() Drives: 2011 LS Join Date: Oct 2010
after sitting for months with used oil in it, I would change it.
Trifecta tune, CAI intake, ADM Race Scoop, Doug Thorley Shorties, Solo High Flow Cats, Magnaflow resonated X-pipe, Flowmaster AMT axle back, Gary's custom front bowtie, rear bowtie delete, tinted windows, headlights, and taillights, debadged fenders, gunmetal gills, gunmetal tailgate (CAMARO)
![]() Drives: 2011 Camaro 2SS/RS Victory Red Join Date: Jan 2011
YES. Be smart.
2010 1LT/RS Traded 5/25/11
I NEED TO CHANGE MY USER NAME!! 2011 2SS/RS ![]() Roto-Fab CAI Heritage Grill |
#6 |
"SHARK" Born Apr.26,2011
Drives: 2011 CGM 2LT/RS Convertible Join Date: Oct 2011
I change mine right before storage and right after storage.
#7 |
I bleed green
The manual even says the oil should be changed once a year, so that's a definite yes.
![]() 2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen. 2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Ideally you should change oil before storage. You want to avoid the contaminants/acids that build up in used oil from sitting in the engine over long periods. Modern oils like M1 have rust inhibitors in them, so it would also depend on how many miles you have on the existing oil before you store it. How many miles that would be is whatever you feel comfortable with.
On my Harleys I average about 3-5K miles a year. So the oil change is done right before storage and I'm usually good until next Fall. Since you have already left your oil in before storage and it's still fairly fresh, I'd leave it. Mobil recommends changing oil after a year regardless of the mileage to ensure the additives are still working. So if you have less than a year on it I don't see an issue.
#9 |
![]() Drives: 2010 Camaro 2SS Join Date: Jun 2010
I store mine then forget about it until spring. Then i Drive it to my shop and change the oil ASAP.
#10 |
Comic Curmudgeon
Drives: 2010 Camaro 2SS-2010 VW CC Sport Join Date: Mar 2008
I change my oil in the fal before storing and again inthe spring.... Makes sense to me!
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name. |
#11 |
Drives: 2010 Camaro Join Date: Feb 2010
Oil Change
Every 3 to 5 thousand miles or every 6 months.
#12 |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
CHANGE IT......even the manual has you changing it at least once a year regardless of the number of miles put on the car. Acids will build up in the oils over time.
#13 |
I can understand before and after for the first LONG sit, but every year? Why not just drain the oil and let it sit? For this year I am just going to go as is, if down the road I feel it needs changed Ill do it, then again before storage as the "once a year" manual suggests. It sounds like there are a lot of old habits here, not that that is a bad thing, but with the new synthetic stuff, its supposed to last up near 10,000 miles. Definatly not going to change it every 3000. Id still be 70% since I only put on about 2500 and am at 78%. But once a year before storage no matter the miles sounds like the best way to go.
#14 |
| How to change your oil in V6 | trooper182 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 20 | 12-16-2012 07:08 AM |
| Should I trust my oil life computer? | 2011CamaroRS/SS | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 39 | 11-15-2011 11:10 PM |
| OIL CATCH CANS | john468 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 5 | 09-16-2010 03:02 PM |
