RIP - Convertible SS
Drives: '13 Mustang Boss 302 - RED Join Date: Apr 2011
******** X2 Connector Help! HURRY!
Guys,
In the middle of my stereo install and I'm wiring the X2 speaker wire to my amp. Problem: My X2 connector has two sets of wire marked LEFT FRONT. ![]() One set is green and one set is white. The green set is right above (or below) the RIGHT FRONT (gray wires) The white set is in the next slot over....toward the middle. Which is of the two is actually the LEFT REAR? Thanks!! To Steve: I'm a small business owner as well in the service industry. I answer my phone anytime it rings. If I'm not in the office, the phone gets forwarded to my cell. It's all about customer service my man! You need to be easier to get in touch with if you are going to make specialty products. JMO. |
![]() Drives: 2010 camaro 2LT/Rally Yellow Join Date: Feb 2012
hi, left rear would be the green set, the white set is left front, hope this helps
EATIT.... are you sure? Do you have a X2 in your hand or installed one? Just wanna make sure.
![]() Drives: 2010 1SS/RS SIM L99 Join Date: Jul 2009
Hi have the top half of my X2 in my hand. EATIT is correct:
GREEN - Left Rear PURPLE - Right Rear WHITE - Left Front GRAY - Right Front |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
All of our harnesses now use eia standards for wire color. This is different from the first couple versions where we allowed the manufacturer to select the colors they wanted to use. We paid more to achieve this, but it makes for a much better harness overall. EIA is the industry standard that you would find on any aftermarket radio for instance. That way the colors can be instanty recognized without the need for a key or legend. If you have installed a few aftermarket decks, you probably have these colors memorized already. If not, I have provided a full chart below.
Wire Color Function white w/ orange stripe 12v amp turn-on purple wires right rear channel solid is+ blk stripe is- green wires left rear channel solid is+ blk stripe is- gray wires right front channel solid is+ blk stripe is- white wires left front channel solid is+ blk stripe is- ------------------------------------------------------------------- |
#6 |
Thanks a bunch guys.....try and finish up tomorrow.
| ******** 2010-2012 Camaro Large Drivers Side Stealth Enclosure (Questions) | NyCTempting2LT | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 3 | 03-12-2012 09:18 AM |
| FS: ******** FARK package w/ Alpine Amp | UNDsioux | Audio / Visual / Electronics/ Gauges / Nav | 16 | 03-05-2012 11:00 PM |
| Selling my ******** Boxes and Subs | 2012transform | Audio / Visual / Electronics/ Gauges / Nav | 2 | 02-01-2012 06:05 AM |
| ******** Front Firing Box Pics | FurySS | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 05-30-2011 09:34 PM |
| ******** poll | BriCo84 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 29 | 11-09-2010 12:51 PM |
