Oil filter change out?
So, our DIC says you can go til about 10% then we change our oil. That is roughly around 8,000 miles ish. In the past we or I changed my oil at 2,500 miles. So if we can go 8000 miles on an oil change, what about changing out the filter halfway?
Has anyone done this or thought of this? I run K & N oil filters in mine and change my oil at 6,000 miles. IDC what GM or the DIC says, it is cheaper to buy oil than replacing parts or an engine IMO. |
![]() ![]() ![]() ![]() ![]() Drives: 2011 ss camaro Join Date: Aug 2010
use this filter.
mobile filter: M1-113 ![]()
10/28/2010 got it
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
All of my vehicles use synthetic oil and good quality filters. I change the oil and filter, 3,000 miles later I change the filter and top off the oil, 3,000 later I change everything again. My Saturn SL2 has 185,000, my Chevy 1500 P/U with a 4.8L has 253,000. Only 700 miles on 2012 2LT. Amsoil/Mobil1 or Royal Purple are my choices on my oils. Wix or Hastings filters are my preference. YES!!! an oil change/filter is cheaper than a major repair.
Let's go Rangers!
He has a V6, the correct Mobil filter is M1C-254.
OP, I would NEVER go that far on an oil change especially with the LLT engine and time timing changes issues. If I were you I'd go full synthetic and change every 5K miles. |
I use Mobil 1 full synthetic in mine.
#6 | |
![]() Dealer told me I should change the oil every 4000 to 4500 and regular conventional oil was fine |
#7 | |
Let's go Rangers!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Exige, Miata, Ghia Join Date: Jun 2011
I change oil and filter every 5k. I don't follow the DIC.
#9 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
The K&N and Mobil 1 oil filter are made by Champion labs. Either filter can go the duration of the OLM with ease.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 06:11 PM |
Need Mechanics Help with Oil Pressure Issue on 1999 3.8 Camaro | Solocus | 4th Generation Camaros | 8 | 05-06-2011 09:49 AM |
How to see if oil is in intake manifold? | CamaroC-17 | 5th Gen Camaro SS LS LT General Discussions | 53 | 03-23-2011 05:06 PM |
OIL CATCH CANS | john468 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 5 | 09-16-2010 02:02 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
