Old 03-16-2012, 01:03 AM   #1
bngummow
HT
bngummow's Avatar
Drives: Camaro SS
dome light blown fuse?
im not sure what to do right now. i was setting up my footwell lighting and i accidently touched the ground to power, and the power is connected to the dome light and the dome light went out. I just expected it to come back on, but it still hasnt come on...does anyone know what i can do to fix this?
bngummow is offline   Reply With Quote
Old 03-16-2012, 05:43 AM   #2
Sharkycsi
Sharkycsi's Avatar
Drives: 2010 Camaro 2SS
I know this sounds stupid, but did you check the fuse for the dome light? If you have and the fuse is good, I would replace the dome light.
Sharkycsi is offline   Reply With Quote
Old 03-16-2012, 04:32 PM   #3
MackMan
Camaro CRAZY
MackMan's Avatar
Drives: 2019 1SS/1LE
I blew the fuse for this... it's a 20A fuse I believe. Went to autozone and bought a new one. I'll see if I can find out which one it is exactly. Can't remember.
Edit: It's fuse #33 - 20 amp and it's yellow.
MACKMAN // 1LE_ORNGE
MackMan is offline   Reply With Quote
Old 03-16-2012, 07:59 PM   #4
bngummow
HT
bngummow's Avatar
Drives: Camaro SS
thanks AACstyle but that was not the problem.
Mack, i will try replacing the fuse and hope for the best. Ill let you know what happens. thanks man
Old 03-16-2012, 08:16 PM   #5
bngummow
HT
bngummow's Avatar
Drives: Camaro SS
would you be able to send me the url of it? i cant find it for some reason. thanks!
Old 03-17-2012, 10:22 AM   #6
MackMan
Camaro CRAZY
MackMan's Avatar
What do you mean the URL of it? Just pop open the fuse box and look for #33.
Old 03-17-2012, 03:20 PM   #7
bngummow
HT
bngummow's Avatar
Drives: Camaro SS
haha sorry i dont even know what i was trying to say there...well anyways i went and bought some 20A fuses and popped it right in and that was the problem. And i just learned that there is a tool used to remove the fuses inside the fuse box. Pretty cool. Thanks for the help MackMan
Old 03-17-2012, 06:41 PM   #8
MackMan
Camaro CRAZY
MackMan's Avatar
Awesome! Glad it fixed it. Didn't know there was a tool for taking them out I usually just use needle nose pliers. Works like a charm.
dome light fuse blown
LED Dome Light Conversion + review (pics included) AdamCzap Cosmetics and Lighting Modification Discussions 34 03-09-2015 05:30 AM
Dome light lens removal? camaroaarp Cosmetics and Lighting Modification Discussions 5 10-06-2011 08:53 AM
Dome light options Toasty Cosmetics and Lighting Modification Discussions 3 04-22-2011 06:07 PM
DIY - Footwell LED lighting In tune with Dome Light markmass Camaro DIY & HOW-TO instructions & discussions 52 09-03-2010 09:00 PM
