Old 03-17-2012, 10:42 AM   #1
IROCanSS
Drives: 89 IROC 350
How often do you need to put air in your tire?
I notice that the air pressure somehow goes down in my tires. Usually down a pound or two! Anyone else have this problem? Do you think I have a bad seal? Will the dealer warranty this? Can I sue GM or Pirelli?
How often do you have to add air?
Sent while on baby duty.... please sleep
Old 03-17-2012, 10:45 AM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
In two and a half years I have only added air a couple of times. Is it all four tires or just one of them?
Old 03-17-2012, 10:48 AM   #3
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
I thought I was the only one with this issue. I also noticed that my tires read lower when sitting in the garage than they do after I've been driving for a while.
Old 03-17-2012, 10:50 AM   #4
IROCanSS
Drives: 89 IROC 350
Typically all 4 lose an equal amount. Can I trust the DIC? I usually keep them about 34/35 psi per my air gauge but sometimes the tire pressure light is on and when I flip through all 4 are typically the same, just low... Maybe 31/32 psi?
Old 03-17-2012, 10:50 AM   #5
Stex
Drives: 67 goat, 69 goat ram air III
Temp changes your air pressure up for warmer down for colder, read this:
http://www.tirerack.com/winter/tech/...jsp?techid=73&
Stex is offline   Reply With Quote
Old 03-17-2012, 10:52 AM   #6
Vengeance Graphix
Vengeance Graphix's Avatar
in almost 2 years of owning ive filled the tires twice and that was only in the winter when the temp changed
Old 03-17-2012, 10:53 AM   #7
oldfriend
Drives: Fiat 500 E
DUH , friction makes the air temperature rise ,hence expending therefore pressure going up .
Old 03-17-2012, 10:55 AM   #8
WadeWilson
How U Doin?
WadeWilson's Avatar
I'm surprised someone actually took my post seriously but thanks Bill Nye!!
Old 03-17-2012, 11:00 AM   #9
bhall82
Drives: 2011 SS/RS
How often do I need remove the trunk carpet so the exhaust gasses can escape since they seep in there?
bhall82 is offline   Reply With Quote
Old 03-17-2012, 11:01 AM   #10
SSBlack
Drives: 2010 2SS/RS JFB
Months go by with nothing, then I'm adding air here and there. Definitely temperature related.
SSBlack is offline   Reply With Quote
Old 03-17-2012, 11:01 AM   #11
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
I've also noticed that if I have one window open and one closed at high way speeds that the air pressure inside the car seems to rise. Ive had it to the dealer repeatedly and they think the fan goes into super high speed mode and compresses more air inside the car but don't know why. My tires always have more air in them than recommended when I get it out in the spring than it did prior to over inflating them before storage. My dealer has been in contact with Goodyear on this but they don't seem to know very much about the Pirellis. I think I'm going to check into lemon laws over these obvious manufacture defects.
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 03-17-2012, 11:02 AM   #12
IROCanSS
Drives: 89 IROC 350
Go troll somewhere else!
Exhaust gasses don't seep in the trunk. It's CO2 that's exhaled and builds up in there.
Old 03-17-2012, 11:07 AM   #13
bhall82
Drives: 2011 SS/RS
Oh ok. Thank you for the clarification IROCanSS. I will install a CO2 detector back there
Old 03-17-2012, 11:11 AM   #14
IROCanSS
Drives: 89 IROC 350
Good idea. Don't want the trunk monkey getting poisoned.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Breath clean Air GmPartsDirect.com Interior Parts & Accessories 0 03-30-2011 05:58 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
