Old 03-18-2012, 07:31 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
V6 Brakes
Need new rotors and pads for my V6. any suggestions/experince?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 03-19-2012, 11:20 AM   #2
JohnZ
JohnZ's Avatar
nobody?
Old 03-19-2012, 05:17 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
If you don't want to move up to the V8 Brembos a good place to start would be an OEM replacement rotor and an upgraded street pad. We like the Hawk HPS pads for a street and very occasional track pad for it's increase in stopping power and relatively good street manners. Given proper bed in procedures with a new rotor they should be a great street setup for you!
Old 03-20-2012, 02:04 AM   #4
JohnZ
JohnZ's Avatar
Thanks Pfadt, what do you think about slotted rotors?
Old 03-20-2012, 08:06 AM   #5
blackTT600
Drives: 2011 2LT M6 SC
Pfadt- on this subject do you think the the bias would be all f#@ked up if I went Brembos up front and left the stock V6 caliper in back? steel lines, slotted rotors, and good pads all around.
thanks for your input.
blackTT600 is offline   Reply With Quote
Old 03-20-2012, 12:11 PM   #6
PfadtRacing
For a street car slotted are going to work just fine. For a track car slots can work as well, but try and make sure that during construction of the rotors the slots are cast into the rotor rather than machined in after. Post casting machine work has a potential of weakening material and causing cracking.
Unless it's a show or car avoid drilled rotors... absolutely avoid drilled rotors if you ever plan on tracking the car.
Probably not a huge deal. The CTS-V fronts we run with the V8 Rears represent a relatively large change in the front brakes only and that setup runs great. A V8 front only upgrade on a V6 isn't something we've experimented with, but I wouldn't imagine there would be a huge problem with it, especially for a street car.
Old 03-20-2012, 05:35 PM   #7
JohnZ
JohnZ's Avatar
Sounds good, I was only planning on slotted (at the most). NO DRILLING. Are there any brands you reccomend? sponsors or not, you can message me if you like.
Old 03-20-2012, 05:58 PM   #8
blackTT600
Great thanks, that seems to be the general consensas. That should save me a good $300 that will go right in to my turbos lol.
Old 03-20-2012, 06:00 PM   #9
JohnZ
JohnZ's Avatar
Im looking at Power Slot Rotors, any thoughts?
SS brakes vs V6 brakes weights? DietCoke Suspension / Brakes / Chassis 10 10-25-2011 09:13 PM
Brembo Brakes Set for your V6 Brake Set freemaSSon Suspension / Chassis / Brakes 12 10-04-2011 08:42 AM
Looking to Trade for V6 Brakes in Connecticut scottywheels Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 6 09-29-2011 04:36 PM
IF You are running V6 brakes with 16" Wheels get in here please. Squintz Palladoris Wheels and Tires Talk Sponsored by The Tire Rack 3 09-08-2011 11:52 AM
has anybody changed the v6 brakes to the SS brakes? camarowa Suspension / Brakes / Chassis 19 01-24-2010 09:12 AM
