Drives: 2011 CG 2SS Join Date: Oct 2009
The "Five" HP/TQ Levels of the ECS Supercharger Systems
We get this question asked a lot in-house and on the boards here... Well, your base kit will make "XXX"? If I add meth it will be "XXX"? How about cam will it be "XXX"? If I do a forged motor what will I make "XXX"?
Well here is a QUICK guide to the ECS Supercharger System, horsepower levels. Levels 1-4 are achieved with the same supercharger, and supercharger head unit pulley. Since we use a restrictor plate design, you will never have to buy another pulley from Levels 1-4. When you reach the Level 5++, you will be purchasing a YSi head unit, and our 10-Rib drive system (We accept trade-ins on all 8-Rib systems and the Novi SL1500 head units). **All horsepower gains are estimated, some vehicles will make more or less power than the below advertised figures** From Top To Bottom: Dyno #1 Base Kit, STOCK Vehicle besides Kit, Stock Bottom End 624rwhp/589rwtq Dyno #2 Base Kit, ECS Alky Control System, ARH LTs, Stock Cam, Stock Bottom End 754rwhp/695rwtq Dyno #3 Base Kit, ECS Alky Control System, ARH LTs, ECS Big Blower Camshaft Package, Stock Bottom End 833rwhp/732rwtq Dyno #4 Base Kit, ECS Alky, ECS Big Blower Camshaft Package, ARH LTs, ECS 417ci 847rwhp/764rwtq Dyno #5 Base Kit, ARH LTs, Upgrade to 10-Rib Drive, Upgrade to YSi, RHS 427ci 1028rwhp/888rwtq Our base kit is enough to get you going and will NEVER require a bracket, ducting, or intercooler upgrade to reach the top tier HP goals you have set forth. The YSi is a direct bolt-on to our current brackets. |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
So you got 624rwhp with JUST your s/c and tune?
damn. How much is it boosting? |
Wow.
What type of blower is it? |
M6 9 second club
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
How about needed fuel system upgrades for each kit and pricing???
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff #BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning Check out my youtube channel: http://www.youtube.com/user/6410Jrod Follow me on Instagram: @J_Rod6410 |
#6 |
Fabricator
Drives: 2011 2SS Summit White Join Date: Jun 2011
The link on the website suggests its a complete kit in every sense of the word.
Great numbers. Do any of the bigger kits use A-W coolers instead?
Roto-fab CAI
Unobtainium Welding Exhaust ARH LT's 393whp L99 GPI VVT Turbo Cam-in |
#7 | |
Yes it is a COMPLETE kit out of the box to bolt-on for the Level "1". -------------------------- Our kits do NOT require bumper removal. No more risk of scratching the bumper, or the tedious work of removing & reinstalling your bumper with a helper. Base systems come complete with a polished headunit, matte black powder coated bracket package and polished charge piping, an industry standard Tial 50mm blowoff valve, a Kenne Bell Boost-A-Pump and 60lb Motron injectors, and a high flow front mounted air to air intercooler system in addition to a dedicated Crank pulley and HD Tensioner assembly. The kits are complete with all necessary hardware, silicone hoses and belts. System Contents & Features: Kit adds approximately 200hp to otherwise stock vehicles, and the capability to deliver far more on modified cars. Belt driven NOVI 1500 centrifugal supercharger provides unmatched reliability (Vortech YSI upgrade available) Fuel management upgrade includes a Kenne Bell Boost A Pump and 60# injectors for safe, reliable operation Self contained oiling for ease of installation and the best possible lubrication and cooling for the supercharger Braided Stainless steel oil drain line Tial Q OR Tial Qr 50mm Blowoff Valve. Billet aluminum supercharger mounting bracket assembly includes steel double, walled ball bearing idlers, Crank pulley, drive belt and all necessary hardware Crank pin kit and new GM Crank bolt included High-flow, reusable air filter Air inlet restrictor plate integrated into system provides greater low RPM hp & torque while maintaining safe peak RPM boost levels PCV oil separator to eliminate oil vapor from intake ECS Valve Cover Breather Inlet and discharge duct connections utilize heat-resistant silicon sleeves and premium quality stainless steel clamps Large, thermally efficient air to air intercooler System is designed to work with factory cooling system Heavy duty belt tensioner with double walled ball bearing idlers to ensure proper belt tracking and traction Kit comes with new NGK TR-6 spark plugs New 160 degree thermostat to ensure adequate cooling Complete kit fits under stock hood 6061 aluminum ducting Standard kit comes with polished head unit, matte black powder coated brackets and matte black ducting All of the ECS Supercharger Kits come with the genuine Tial blow-off valves. You can select the Q (Loud) or Qr (Quieter) valve below, no additional cost! * Optional: Powder coated Brackets & Ducting to specific paint code colors. Will match your SS exterior paint! ------------------------------------- ECS SC1500 Gen V Camaro Kit |
#8 |
#9 |
We have not used A-W coolers on anything but the drag cars around here. Our A-A intercoolers are so efficient... This same A-A intercooler holds the Supercharged C6Z Record; 8.57 @ 158 in the 1/4. Just in our C6's its laid out horizontal vs. vertical on the Camaro's.
#10 |
Gearing up for Camaro5... We'll have some nice deals at the Fest on all five levels, and parts only if need be!
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
too bad these arent legal in cali...:(
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Exige, Miata, Ghia Join Date: Jun 2011
Quick question. Does this come with tuning or do I have to get it dyno tuned locally?
#13 |
![]() Drives: 11 Camaro 2SS Join Date: Oct 2011
Can i get price installed & tuned (PM)... I'll drive to NJ!
#14 |
Drives: 8 second C5 Drag Car, C6 Road racer Join Date: Sep 2009
We can send a base program for you that will be basically finished, but there are too many variables to say it is a "race ready" tune. The start up file is N/C btw with the purchase of the supercharger kit.
| *Dyno Pic* ECS Supercharger Kit, Alky, Stock Cam - 754RWHP / 695RWTQ | Sales @ ECS | Forced Induction - V8 | 22 | 02-07-2012 07:54 AM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 09:33 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 03:11 AM |
| AirAid Cold Air Intake anyone? | FLYNNZL1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 10:05 PM |
| Procharger supercharger now available for new Camaro | khislop007 | Forced Induction - V8 | 55 | 07-07-2009 05:15 PM |
