03-19-2012, 04:21 PM | #1 |
Drives: Turbocharged 2010 GLOSSY NARDO GREY Join Date: May 2010
Question
Hey everyone. Unbelievable weather eh?
Today ..... i have been getting a " service battery charging system" warning It has been coming and going The volts are bang on Anyone ever see that Advice? Thanks Bob |
03-19-2012, 04:30 PM | #2 |
Drives: 2004 GTO Join Date: Feb 2012
If your gague is bang on then I would drop bye any battery shop and have them test your battery for you and make sure you are not having any issues with your battery.
03-19-2012, 06:49 PM | #3 |
Royal Cdn. Navy (Retired)
Drives: 2010 Camaro 2SSRS Join Date: May 2010
Have them check your alternator if thats ok, have them run a load test on your battery, might just be a loose or corroded connection...your guage should be on the plus side after starting engine.
03-19-2012, 07:19 PM | #4 |
Thanks guys
The gauge is bang on never really fluctuates by put the warning is intermittent The car has to go in for warranty work, ie heated drivers seat turns on shuts off after 10 secs USB port does not ale ays connect with the iPod Problem is I have that 76 mm thing under the hood Think they will notice it |
03-20-2012, 07:31 AM | #5 | |
Drives: 2010 Camaro SS Join Date: Apr 2009
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
Similar Threads | ||||
New member, hi! Question about the GFX package... | TheDayday | New Member Introductions | 5 | 04-24-2011 02:32 PM |
stereo question | bigted83 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 04-07-2011 04:56 PM |
Question about tire sizes | Jram1588 | Wheels and Tires Talk Sponsored by The Tire Rack | 9 | 07-17-2010 07:27 AM |
Custom wheel offset question ... | Bowtie Junkman | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 04-23-2010 05:16 PM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
