Old 03-20-2012, 01:00 PM   #1
josephs8
josephs8's Avatar
Drives: 2011 Yellow 2LT RS Camaro
Anyone else have a XD700/5
Wondering if anyone else has a XD700/5. I am wondering what you set for your Input Sensitivity and what you setup your HP Filter Mode for Channel 1&2 and Filter Mode for Channel 3&4. What frequency have you setup to filter at? I am just about ready to get mine completely hooked up but just wanted to see what settings other people had to try out a whole combination of settings.
I am going to connect the rear 6x9 tweeters later today with the adapter supplied. Not sure how many people have done that yet.
josephs8 is offline   Reply With Quote
Old 03-20-2012, 06:52 PM   #2
EDGE_
EDGE_'s Avatar
Drives: 2010 1SS/RS SIM L99
I am using a XD700/5 with a JL Audio 12W3v3-2 sub-woofer.
I configured the Input Sensitivity using the 9-step calibration procedure in the manual with a 2 ohm nominal impedance.
Channel 1&2 - HP Filter 1X. Filter Freq - 80
Channel 3&4 - Filter Mode OFF
EDGE_ is offline   Reply With Quote
Old 03-21-2012, 05:31 AM   #3
josephs8
josephs8's Avatar
Thanks EDGE_
Thats the exact configuration I am going with. Going to order my sub (12w3v3-2) very soon.
what filtering did you do on your sub?
Did you end up hooking up your tweeters in the rear? I am trying to decide if I want to order the bass blockers or not to hook them up.
Old 03-21-2012, 03:32 PM   #4
EDGE_
EDGE_'s Avatar
I bought the bass blockers but haven't hooked them up yet. I decided to try them for awhile without it and I am going to install them this weekend and run it for a week and then decide which I like best.
Right now I am running the sub at 24dB and it sounds pretty good but I'll probably switch it to 12dB.
