Old 05-03-2009, 06:47 PM   #1
my2010camaross
ss
Drives: all black ss
Tire prices from the tire guy.
There has been some discussion about tire prices and the ridiculous amount each tire will cost us. I am urging everyone to check out the yokohama parada spec x, yes it is v rated, but is rated a the same speed as the zr tires coming on our ss's. they are very cheap in comparisson to the pirellis that are coming stock with this vehicle. check em out.
ordered 10-20-08 all black ss with sunroof, that s it.everything else will most likley be done by the dealership, or my uncles shop.
my2010camaross is offline   Reply With Quote
Old 05-03-2009, 06:51 PM   #2
Lovestanda
Large Member
Lovestanda's Avatar
Drives: Yugo SS
toyo
Anyone run This tire on another car?
Lovestanda is offline   Reply With Quote
Old 05-03-2009, 06:51 PM   #3
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Does Goodyear make a run flat SS Camaro 20 inchers like the ones on the Vette? If so how much? I would like to have a little more protection since we don't have a spare!!
Hoss is offline   Reply With Quote
Old 05-03-2009, 07:41 PM   #4
redjewel
Drives: 2010 Camaro 2SS RJT
Pirelli only one making matching tires right now for front and rear.
Not to mention the Spec X is a tire made for SUV'S.
The Spec X is a good tire for the correct applicaton.
redjewel is offline   Reply With Quote
Old 05-03-2009, 08:00 PM   #5
redjewel
It is not rated at the same speed rating.The SS comes with a ZR tire with a service description of Y = 186 MPH while VR=149 MPH. Big difference but I highly doubt very many people are going to hit the 149 mark. I just don't like it very much when people go throwing out information that can mislead others.
You should stay with a tire that has the same type qualities as your original tires including load index and speed rating. I would also not put a tire made for another type of vehicle (SUV and Crossover for the spec x) on my performance car.
Until other manufacturers come out with tires that are staggered correctly for the Camaro we will be stuck with Pirelli if you want matching tires.
Old 05-04-2009, 11:04 AM   #6
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Before claiming that others are putting out misleading information, please take the time to look into the information yourself.
The Spec-X vehicle applications list also includes the Chrysler 300C and the Dodge Charger. This tire is not only for SUVs and trucks. That is just the primary market for 20" tires right now.
http://www.yokohamatire.com/tires/parada_specx.pdf
rolnslo is offline   Reply With Quote
Old 05-04-2009, 12:24 PM   #7
redjewel
The spec x is neither the correct speed rating or load index for the Camaro. You lose 440 pounds of load capacity on the front with the spec x. Just sayin.
Old 05-04-2009, 01:14 PM   #8
rolnslo
Rolling along...
rolnslo's Avatar
440 pounds sounds like a lot until you look at the entire picture:
Pirelli P-Zero (2@245/45ZR20 load=1929lb, 2@275/40ZR20 load=2094lbs) = total load capacity = 8046lbs.
Yokohama Parada Spec-X (2@245/45R20 load=1709lbs, 2@275/40R20 load=2094lbs) = total load capacity = 7606lbs.
Camaro GVWR: 4551 lbs (2144lbs front, 2407lbs rear).
As for the speed rating, Spec-X is V-rated (149mph), P-Zero is Y-rated (186mph). Top speed in the SS is governed to 155mph and as we saw this weekend in another thread, you may have other issues at that speed too.
All I'm saying is that specs are specs and you should buy what you feel comfortable buying when it comes to tires. If you are going to be doing top speed runs, then spend the extra money for the Pirellis because your life will depend on it. If you are like 80%+ of the typical Camaro drivers out there, you'll never go over 100mph, let alone 149mph so you can probably get by with the Spec-X tires and have an extra $1k in your pocket (Spec-X set price=$558, P-Zero set price=$1610) plus nearly twice the treadwear rating of the P-Zero (Spec-X: 420A A, P-Zero: 220AA A).
Old 05-04-2009, 01:18 PM   #9
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Nitto makes a 20" 555 tire available through places like Summit Racing
they range in size from 225 to 305 and below are a couple of prices:
255 / 35R20 $135.95
305/ 35R20 $345.95
W Speed Rating (168 mph - exotic car rating)
Treadwear up to 300
Old 05-04-2009, 01:24 PM   #10
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Maximum load doesn't matter unless you're going to run maximum pressure*, which I'm sure nobody here will do. At the same size and same pressure, the tire will have the same load rating. Load-inflation charts are standardized across the tire industry.
http://www.geocities.com/barrystiretech/loadtables.html
*: Maybe not exactly the maximum pressure, but almost certainly a pressure far higher than you'll be using.
Anyway, if the tires have a speed rating that will cover all your driving and are the right size, they will be sufficiently safe and not hurt anything. Then you only have to worry about performance - traction, handling, treadwear, ride, noise, aesthetics, etc.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-04-2009, 02:17 PM   #11
my2010camaross
ss
alot of tires have the suv/street characteristic, these can be and will be used on my car.
Old 05-04-2009, 02:19 PM   #12
my2010camaross
ss
+1
Old 05-04-2009, 02:21 PM   #13
my2010camaross
ss
the spec x is plent sufficient, there are several vehichles i have put these tires on that are not suv or crossovers, some zr tires are rated at 149, obviously the y speed rated are not.
Old 05-04-2009, 03:02 PM   #14
GothamCamaro
Then you're gonna love me
GothamCamaro's Avatar
Drives: 2010 Black Camaro Tumbler RS
I agree with that thought as well. These Yokohama Parada Spec-X tires are All Seasons or Summer? Looking for All Season options for the winter time (weather is 85% cold and 15% snow)
Own- "Does it come in Black?" Exterior/ Grey Interior 2LT/RS Automatic
_____________________________________
The Batman would only drive a 2010 Camaro and buy from Camaro Scotty. 'Nuff said.
Anyone that knows of a place that is making the Concept Shifter for the new Camaro. (Auto specifically) Please let me know.
Order# NDTMVP Ordered 10/23/08.
2000 on 5/21/09... It begins.....
4B00 on 6/26/09... In transit to the Cave
5000 on 7/6/09 it waits for my arrival!
1000000 on 7/10/09 The Tumbler is in the Cave!
GothamCamaro is offline   Reply With Quote
Ouch, Tire Prices on TireRack for 2SS Scott@Bjorn3D Wheels and Tires Talk Sponsored by The Tire Rack 34 08-16-2009 03:28 AM
camaro tire prices Ltdodge Wheels and Tires Talk Sponsored by The Tire Rack 6 04-26-2009 02:01 AM
Spare Tire and Painted Wheels Question jmcbeth Camaro Price | Ordering | Tracking | Dealers Discussions 5 02-05-2009 06:31 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
