Old 04-07-2012, 05:43 PM   #1
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
I need a 2.5" o.d. to 3" o.d. exhaust adapter!!
I bought the MBRP exhaust tips that match the ground effects kit. The thing is they are for a 3" exhaust system. The clamps on the tips have a 3" inner diameter. My exhaust system(Borla Atak) have a 2.5" outer diameter. I want to use sleeve clamps to hook the adapters up to the exhaust system, which means I need a 2.5" outer diameter to 3" outer diameter adapter. The only adapters I can find are 2.5" i.d to 3" o.d So, is there anywhere I can get these? Do they even exhist?
Tyler360 is offline   Reply With Quote
Old 04-07-2012, 05:57 PM   #2
BigRed585Lbs
Drives: Sierra and Tahoe
Any competent muffler shop should be able to expand the 2.5"id to a 2.5"od without any trouble.
BigRed585Lbs is offline   Reply With Quote
Old 04-07-2012, 07:32 PM   #3
Tyler360
Tyler360's Avatar
It would need to be compressed, not expanded. 2.5 I.d is bigger than 2.5 o.d, but thanks for trying to help, I appreciate it
Old 04-07-2012, 08:43 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
I think what he is trying to say would be to have the muffler shop expand your Borla catback to fit the 3" tips. They might be able to expand it to just under 3" so that the tips will fit pretty snug. Then you could probably have them welded on.
I would say to find a local muffler shop and see what they could do for you.
Build Journal
Old 04-07-2012, 10:28 PM   #5
Tyler360
Tyler360's Avatar
Ah. The tips fit the adapter fine. It's between the adapter and the pipe that I'm having a problem. I'm trying to avoid welding and U-clamps. What I want is an adapter with a diameter that matches my pipe so I can put a band clamp over it. Which means the adapter has to have a 3" outer diameter on one end, and a 2.5" outer diameter on the other end, which would match the pipes outer diameter. Thanks for your input
adapter, clamp, exhaust, mbrp, tip
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
Sound level difference: 2.5" vs 3" exhaust plastrd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-11-2011 06:09 PM
MAGNAFLOW Cat-Back / Axle-Back Exhaust Systems | FREE Shipping Apex Paul V8 Bolt-Ons & Tunes 134 01-24-2011 01:56 AM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
