Old 04-13-2012, 05:02 PM   #1
RS-Camaro123
Drives: Inferno orange
Metra Kit?!?!
Hey everyone, I was wondering if it is hard to install the Metra kit for a camaro rs?!? Im only 17 years old and was wondering if I would be able to do it. On a scale of 1-10, How hard is it?!
RS-Camaro123 is offline   Reply With Quote
Old 04-13-2012, 05:11 PM   #2
SS King
SS King's Avatar
Drives: a Panty Dropper
The Camaro metra kit has ALOT of wires but follow the instructions step by step and its easy I'd say it's a 3.5 out of 10. Pm me if u have any issues
SS King is offline   Reply With Quote
Old 04-13-2012, 11:39 PM   #3
3GPa
3GPa's Avatar
Drives: SOLD/2SS/RS Painted Rally Stripes
The Dash Kit Install was easy. It worked Perfectly.
My only issue was the instructions on the wiring for the new stereo and the interface. I found it confusing to me, because I forgot that I had a factory amp. If you can read and understand you will not have any problems.
Good Luck.
I will be happy to answer any questions also.
Gus
3GPa is offline   Reply With Quote
Old 04-14-2012, 01:43 AM   #4
RS-Camaro123
Thanks Guys!
Old 04-14-2012, 04:34 PM   #5
DaramGeee
Drives: 2010 2LT/RS Camaro
Help Plz!
Help plz.
Hi Everyone. I bought a used Metra Kit and a crappy cheap used boss audio system to try on my 2010 camaro. I got to the wires and hooked everything up and noticed that the audio system was getting really hot. The thing is, I double checked all the wires and everything was correct before I reconnected the battery terminal and turned it on. Then it smoked instantly and doesn't work at all. So now I am sending back the audio system for a refund.
Now the problem is that the Metra Kit doesn't work on my camaro anymore (fans don't respond and stuck on 77 degrees thing) but also I put my stock audio system back together and now that doesn't work either. The a/c fan controls work, but the audio system doesn't turn on and no chime or clicking sound when turn signals are on.
Is there a way to reset everything in order to turn my stock audio system back on along with the chime or clicking noises? Or is the cable the problem whenever the cheap audio system overheated?
DaramGeee is offline   Reply With Quote
Old 04-14-2012, 05:19 PM   #6
SS King
SS King's Avatar
Check your fuses and see if u blew one
Old 04-16-2012, 01:27 AM   #7
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Check the fuse box in the trunk on the passenger side, most likely blew the radio fuse there.
jeffa is offline   Reply With Quote
Old 04-18-2012, 02:51 PM   #8
DaramGeee
Thanks a bunch guys. That was exactly what the problem was, blown fuses. Gonna just stick to the stock audio system for now :( but at least I have some exhausts to install. Hope this doesn't go so bad either
Old 04-18-2012, 04:52 PM   #9
Bluffen
Bluffen's Avatar
Drives: 2013 Sea Ray 220 Sundeck
It's not who you are underneath but what you DO that defines you
Bluffen is offline   Reply With Quote
Metra Dash Kit Install Help skysharker1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 34 10-16-2011 09:36 PM
Metra Dash kit button color vlavaRS Audio / Visual / Electronics/ Gauges / Nav 1 09-08-2011 08:16 AM
Metra kit... 2FST2LIV2YNG2DY Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 02-27-2011 12:26 AM
(1 Only) NEW Kenne Bell 2.8 Camaro Kit $5,999.00!!! (Pics Inside) Total_Perf_Eng Forced Induction 9 12-04-2010 10:20 PM
Metra Kit Bugs/Notes... y2jdmbfan Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 04-14-2010 05:54 PM
