Old 04-18-2012, 02:17 PM   #1
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Bigger washer bottle
I'm thinking of getting a scoop and washer bottle reloc kit for my CAI. My concern is that I live in MN and the replacement washer bottles are not as large as factory. Is this an issue for inclement weather and the need to wash the windshield often, or is the current sizes just fine? If a larger bottle is needed...does anyone even make one that is usable with the ADM Scoop?
Thanks,
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 04-18-2012, 02:18 PM   #2
Dznts
Anabolic Connoisseur
Dznts's Avatar
i have the washer bottle relocation kit on mine and it hasnt been a problem so far.
Old 04-18-2012, 02:32 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
check this DIY and its TOTALLY hidden!
http://www.camaro5.com/forums/showthread.php?t=215789
Old 04-18-2012, 02:39 PM   #4
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
I have a Roto-Fab washer bottle and it hold plenty. It may be just bit smaller than the factory one but not by much.
bpoirier is offline   Reply With Quote
Old 04-18-2012, 03:08 PM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Just keep a spare gallon in the trunk.
Old 04-18-2012, 03:19 PM   #6
Rangore
Rangore's Avatar
I do that already. Didn't need it this winter, but just in case.
Thanks for the link Sir Nuke....unfortunately it only holds a half gallon.
I'm feeling there is no options out there if I want the air scoop. I don't mind the look of the washer bottle kits...just was hoping for something that held more fluid.
Old 04-18-2012, 03:22 PM   #7
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
the Apex bottle you can get with the scoop is only about 1/2 gal. I dont think any are as big as stock.
VR Baron is offline   Reply With Quote
Old 04-18-2012, 03:28 PM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
You can relocate the washer bottle whether you use a scoop or not. I have the Apex scoop and bottle. Their bottle is 1/2 gallon and bolts to the side of the scoop and is hidden behind the driver headlight. It attaches via a hose to a remote filler that you can mount where you want. It makes for a clean under hood look. You can also get the Roto-Fab bottle which mounts behind the airbox. It's bigger but adds to under hood clutter. You can then use either the Apex or ADM scoop. As far as use, the only time I've hit my wash button in 3 years was to test after scoop and bottle install, but I think a half gallon would last a while.
Old 04-18-2012, 03:48 PM   #9
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
Shouldn't be a problem IMO.
Old 04-18-2012, 03:51 PM   #10
Rangore
Rangore's Avatar
I'm hearing ya, mclark10...I drive mine year round though...so it get's plenty of usage.
I'm thinking if I go with the Apex kit...I'll mount the bottle filler outside the air box for easier access.
Old 04-18-2012, 04:05 PM   #11
ZED SLED
ZED SLED's Avatar
That would be the way to go then. PM Apex Chase for pricing. They have a good deal when you by both together as a kit.
Old 04-18-2012, 04:38 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Just get the Apex bottle. It holds 1 pint less then the factory washer bottle does. The factory bottle looks huge but it actually holds less then you would think.
Old 04-18-2012, 04:59 PM   #13
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Is it possible to just relocate the factory bottle to somewhere else?
kjkjr27 is offline   Reply With Quote
Old 04-18-2012, 05:00 PM   #14
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
As huge as it is, I doubt it.
adm scoop, bottle, cai, washer, washer bottle
