Old 04-19-2012, 02:22 AM   #1
FresnoStateDogs
FresnoStateDogs's Avatar
Drives: 2012 2SS/RS LS3
Oil Change
Had my first oil change yesterday. Owners Manual told me the car would tell me when I needed an oil change. The guy at Jiffy Lube looked at me like I had just beat my wife when I told him I was having my first oil change at 10,700 miles. Should I change it more often? The camaro first told me to "change oil soon" at 10,600 miles.
Spiral Ported TB, K&N Typhoon, JBA Performance Cat-back, RX catch can and Oil Breather.
FresnoStateDogs is offline   Reply With Quote
Old 04-19-2012, 02:31 AM   #2
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
oil
every 3,000 here
OHIO SPEED is offline   Reply With Quote
Old 04-19-2012, 02:33 AM   #3
LakeMarySS
LakeMarySS's Avatar
Drives: Black 2010 Camaro 2SS
I change mine every 4000 to 5000. I know cars these days especially those using synthetic oil dont need it as often but old habits die hard.
LakeMarySS is offline   Reply With Quote
Old 04-19-2012, 02:41 AM   #4
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Mine says I have around 50% remaining and I am at approximately 5000 miles. I usually run 7-8000 mile range on my oil.
ZWA SS is offline   Reply With Quote
Old 04-19-2012, 02:43 AM   #5
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
I used to do it every 3k. Do it every 5k now.
Old 04-19-2012, 02:50 AM   #6
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
Changed mine at 500 (after hard break in), 1500, 3000, 5000, 7500(ish) 10,000... prob will after a track day at about 12,000 cuz its been a really long time since I have.
I dont drive it alot, it only has 11,500 and its over 2 years old. But I do alot of track days and the drag strip a couple times.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 04-19-2012, 02:56 AM   #7
5cents
Dave
5cents's Avatar
Drives: 2011 Camaro SS - Black/CGM Stripes
10,000+ miles is a little excessive if you ask me. I don't know if it's true with ALL Camaro models, but my 2SS came with Mobil 1 synthetic oil. My Chevy dealer charges $89.95 for an oil change.
When it comes to conventional oil, I'm old school, every 3 to 4,000 miles, but with the synthetic, I go 7 to 8,000 miles between oil changes. Studies have shown, that with todays engines, frequent oil changes are not only unnecessary, but also a waste of oil and $$$.
One final note, you can do what you want, it's your vehicle, but I would NEVER take anything to Jiffy Lube, or any other quick oil change place for that matter. I've heard too many horror stories about stripped out drain plugs or loose drain plugs that fall out, and those places won't stand behind their mistakes.
5cents is offline   Reply With Quote
Old 04-19-2012, 03:08 AM   #8
FresnoStateDogs
I paid $104 at Jiffy Lube. I know that's a lot but I figured my dealer would charge even more? and I sure as hell wasn't going to take it to a small independent shop. Sounds like the dealer would have been better and cheaper.
But on a side note...I'm afraid to take it to the dealer because I have a K&N CAI. From everything I've read this shouldn't void my warranty but considering my check engine light is coming on because of it...I'm skeptical.
Old 04-19-2012, 03:16 AM   #9
FresnoStateDogs
Originally Posted by OHIO SPEED 2010 View Post
every 3,000 here
Does yours carry conventional?
Old 04-19-2012, 04:05 AM   #10
Sebastian
Drives: Camaro 2011, 6.2L 2SS
i just change my oil here every 5000-6000 kms... even if the oil is on 55 or 65 %, i change it. i personally dont trust this oil check thingi.
Sebastian is offline   Reply With Quote
Old 04-19-2012, 05:16 AM   #11
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
I think 10,000 is to long to wait, no more than 5,000 is a safe way to keep the internals more clean, but its your car your call
1954 Belair-man is offline   Reply With Quote
Old 04-19-2012, 06:32 AM   #12
SSBlack
Drives: 2010 2SS/RS JFB
The dealer is not that much more expensive and that way, GM has records of the maintenance.
SSBlack is offline   Reply With Quote
Old 04-19-2012, 06:37 AM   #13
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
I have waited to 10k miles on most of my vehicles, never had a problem on my Chevies.
I had a Ford way back in the 80s and I changed the oil religiously and documented all the maintenance on the car.........it completely failed me at 47k miles, needless to say-that was the last straw with Ford and I havent owned one since.
Changing your oil is all up to you, I am now at 8000 miles on Lil' Blue and am starting to look at getting the oil changed, I am going to do it myself, I refuse to pay $70~$110 for someone else to do it.
007s 'Vert is offline   Reply With Quote
Old 04-19-2012, 06:45 AM   #14
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Well, for my camaro I change the oil before a garage it for the winter. Which last year was 1500 miles. On my Impala, I change it every 3,000 miles.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
