Semi synthetic or Synthetic oil?
The service man in my dealer shop says he should use semi synthetic oil for my v6 2lt oil change.
But from my knowledge, most people use synthetic oil? He said he'll do the job for 79.99 Is he suggesting semi synthetic oil to rip me off? or is he right? |
Let's go Rangers!
The V6's come with a synthetic blend (he not lying), I quickly upgraded to full synthetic. Mobil 1 FTW!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
the 10 & 11 SS required Mobil 1, the V6 doesn't. As for '12, I think for the SS they now spec a semi-synthetic, not sure about V6. I put synthetic in everything, even my riding mower. Best place to find for sure is right in your owner's manual.
![]() ![]() ![]() Drives: 2011 Coupe, 1LT, A6, No RS Package. Join Date: May 2011
I just put Synthetic in my 1LT. I don't put a lot of mileage on a car so I basically go about a year between oil changes, and Synthetic can handle that better.
Never Underestimate The Power of Forums
ace5.org
Honestly, IMO....(with the V6 only cause I had one) you can run conventional oil as long as you change it when its time to be changed. I didn't see the need to spend the extra money on it with the V6...now the SS gets Mobil 1 synthetic.
Stock...For Now.
#6 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
My car gets Mobil 1 Synthetic.
Now, you might hear that the poor, weak, slow V6 is unworthy of it... but as my dad says, you'll never regret going first class, and everyone knows Mobil 1 is the best. I plan on having my car for the rest of my life so I don't mind paying extra to keep her at her best for as long as possible.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
#7 |
ace5.org
I don't think that is is unworthy of it, I just think using Synthetic in the 3.6 is like putting 93 in the 3.6
Stock...For Now.
#8 | |
#9 | |
ace5.org
![]() I'm not knocking anyone for their choice of oil. But thankfully if you were to choose to use conventional oil your warranty couldn't be voided since the manual doesn't call for synthetic in the V6.
Stock...For Now.
#10 |
Aviation guru
Drives: 10 1SS, 09 Acadia, 90 K1500 Z-71 Join Date: Aug 2010
Royal Purple is what my SS loves.
#11 |
***UPDATE***
The brand of oil I had put in (Synthetic) for my first Oil Change is: AC Delco Dexos 5W-30. It's the same oil that they filled it with from the factory when it was built.
#12 |
Let's go Rangers!
But it does call for Dexos 1, I'm not sure conventional oil is Dexos 1. Does it?
#13 | |
Let's go Rangers!
http://www.acdelcochemicalcatalogue....&page=6&search= Last edited by nyrfan; 04-19-2012 at 03:38 PM. |
#14 |
My dealer told me it needs to at least be a synthetic blend. I just opt for full syn
