Old 04-21-2012, 07:29 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Thoughts on KW Coilovers
Anyone have any experience with KW Coilovers? good or bad. I am considering some KW V1's. Here the link
http://www.modbargains.com/KW-Coilov...7-35261017.htm
Thanks
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-21-2012, 07:43 PM   #2
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
I know we've been speaking over PM's in regards to the KW's, but I wanted to add some factual parts about KW that some guys on the forum might not have known yet. Sure it's a long essay of text, but it is a good read.
KW's have the best material construction quality of any coilover kit that I've seen. KW not only designs and manufacturers the coilovers, but they test them as well, to TUV certification levels. They also do this for each individual name plate which means they do it for Mercedes-Benz, Jaguar, BMW, Audi, Porsche, Chevrolet and more. They also design and valve all the suspension dampers to each individual MODEL within that brand, so you're getting something truly unique.
KW's are designed with street driving in mind, that's what they're designed for unless you talk about the clubsport models. All of KW's essential parts are built in-house, they are not outsourced like a lot of other companies. Though to some, this isn't a big issue, but when you consider that gives them a very big advantage on the quality control of a system, other companies just cannot compete with that.
TUV Certification, as I've touched on before, is the highest quality of certification that a company can receive in Europe. Getting TUV certification requires such a large amount of time to seek this endorsement, it's unbelievable. Each individual part such as the coils, the shocks, and the strut cartridges are individually tested, and then re-tested to insure that it meets or exceeds TUV's very strict requirements.
Here's the kicker! Not only did the KW coilovers pass the TUV's rigorous requirements, but it did so on EVERY ride height setting, including the lowest possible setting available. I highly doubt most other coilover companies have the time or the energy, let alone the money to even do such a thing.
The strut housing/shock bodies are T-304 stainless and they are completely impervious to rust, corrosion, acid rain, salt on the roads and of course any other things you might see such as that. All their brackets are 10.9 rated T-6 Aluminum alloy that are all anodized to prevent corrosion.
The second kicker here, is that KW is also an OE supplier to Eibach ironically, because some of the springs they manufacture actually go onto other coilover kits! Lastly, KW is the OE supplier to all the Mercedes-Benz AMG cars, which is an astonishing fact on itself, a real achievement to any company.
ModBargains.com is offline   Reply With Quote
Old 04-24-2012, 12:43 AM   #3
JohnZ
JohnZ's Avatar
bump
Old 04-24-2012, 08:05 AM   #4
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
wow didn't know all of that!
'24 CT5 Blkwng CF1&2 6spd manual Coastal Blue
SOLD!'23 CT5Blkwng manual Rift Metallic
SOLD!'19 Z06-7Speed and lowered on stock bolts
SOLD'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-24-2012, 08:20 AM   #5
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Arent the V1's non adjustable? If you are going to spend the money for coilovers I would suggest going with the adjustable version.
Squintz Palladoris is offline   Reply With Quote
Old 04-24-2012, 11:38 AM   #6
ModBargains.com
Pretty sweet huh?
V1's are ride height adjustable, and the dampening and rebound adjustments are all pre-set from factory to give you a sporty yet comfortable ride. Think of it as your stock suspension, but a sport version, and that's exactly how it feels.
V3's are of course not only ride height adjustable, but also rebound and dampening adjustable so you can completely re-tune the way the car feels in every situation, and you can do it quite easily as well.
Old 04-24-2012, 01:02 PM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I love my KWV1 coilovers!!
MODS:
