Logic is dead
Aeroforce Interceptor Users - Questions
Hey yo,
After installing the V3 Vortech supercharger (complete kit), I also added a standard Boost/Vacuum guage, as well as an Aeroforce Interceptor gauge. I have been tinkering around with the gauge and have a few questions. I appreciate the thoughts of those with experience of this wonderful guage. 1. The instructions state that you can set the shift light to be used and/or for warning lights in case a parameter gets too high or low. Is anyone using this? If so, what parameters at what ranges? Boosted cars I'm especially interested in. 2. The Air/Fuel condition gauge appears to be functioning, however I'm not sure where it is getting the data, since I do not have a wideband connected. Can anyone clarify? 3. Which fuel status parameter is most useful? Does the DI Fuel Pressure parameter work? I thought I scrolled through it and was not getting a reading. Or am I better off watching injector pulse or duty cycle? What else do I need to know? Thanks.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ - Vortech V3 Supercharger - Kooks Stepped Headers, Magnaflow 16580 - Suspension by Pfadt, Hotchkis. 2007 Trailblazer SS- Sold 2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold 1994 Camaro Z28 - Sold |
Emerald Coast Camaros
Drives: 2010 2SS 6m Join Date: Mar 2010
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
1. That would be the annunciator function. Scroll thru to almost the end, you'll find it there. You can 'annunciate' or warn like a shift light, on either or both of the 2 displayed parameters. Then you will choose which parameters along with values and then whether to annunicate above or below the value.
2. AFR would be the commanded value, not a directly measured value. (kinda useless) 3. Rail pressure seems incorrect. For fuel items, duty cycle is more useful. Sometimes its nice to set both parameter displays to knock retard and annunciate off of them. As I have an electric water pump, I usually display coolant temp along with knock retard. Other things: - the gauge interferes with Onstar diagnostic reporting. - tunning devices don't get along with the gauge if you're using a OBD2 y-cable.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread ![]() |
Logic is dead
Good things, Ducatisl. Thanks very much for that.
Also: How comfortable are you with the IAT read outs? I have been monitoring these, and they look pretty good. With my V3 intercooler, I am generally 3 to 6 degrees above ambient. Sounds about right, and I hope that is accurate. Can you comment on "Desired Fuel Pressure"? Is this another configurable parameter? Mine seems stuck at 6.1 at all times... I'm pretty sure that isn't what I "desire"! Good call also on confirguring the knock retard.
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
if is stuck at 6.1 than that mean your vehicle does not support that particular PID. I believe that's just a carried over numeric value while switching PID's. You can actually get your aeroforce to monitor real time AFR also. Just need to buy the wideband kit seperately. I noticed that all of the PID's on our gauge is not supported especially if you have a manual. Those tranny PID's are useless.
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
I have mine set to alert me if my boost is over 3lbs and my afr is over 12.5. I think that was it. I set it up a while ago. This thread reminds me to check exactly what it was. Lol.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
#6 | |
![]() Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
Todd |
#7 |
Banned
Drives: 2013 CRT ZL1 Join Date: Sep 2012
From what it sounds like AFR is not accurate on this gauge unless you buy the wideband kit..
Can someone give me more detail on this and how to get AFR to work on this gauge. Last edited by CRTZL1; 02-10-2014 at 07:47 AM. |
#8 |
Banned
Answered my own question, not that anyone was anyways!!
#9 | |
![]() ![]() Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2013
I know this thread is old but can someone elaborate on this?
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
What part #?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
