Old 04-24-2012, 06:50 PM   #1
2lt2012
Drives: 2012 camaro 2lt white
check engine light! help
My check engine light just came out p0442.... i read on the forum that it could be the gas cap? but i have aftermarket exhaust which makes me think it could be the exhaust. Should i be worried and have the dealer check it out? also will the dealer void my warranty cause the exhaust? thx
2lt2012 is offline   Reply With Quote
Old 04-24-2012, 06:54 PM   #2
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Probably your fuel cap.
http://www.obd-codes.com/p0442
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 04-24-2012, 06:58 PM   #3
2lt2012
should the check engine go away or do i need to clear it to see if the tightening of the gas cap solves the problem? how do i clear the codes if i have to?
Old 04-24-2012, 07:24 PM   #4
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Should go away on it's own after a couple drive cycles. Or take it to AutoZone they can reset it for free.
Old 04-24-2012, 07:34 PM   #5
68/2010
Emerald Coast Camaros
68/2010's Avatar
Drives: 2010 2SS Rally Yellow
Well, mine came on like that and it wasn't the gas cap. it was the sensor in the gas tank with they had to drop my tank and replace it.
Old 04-24-2012, 07:37 PM   #6
2lt2012
OK, i am going to wait and see if the check engine light goes away....if i do happen to go to the dealer, should i have a problem with my exhaust voiding the warranty?
Old 04-24-2012, 08:22 PM   #7
68/2010
68/2010's Avatar
I myself think you should be fine. I have a mufller delete and they said nothing on mine.
Old 04-24-2012, 08:31 PM   #8
2lt2012
Ok thanks
Old 04-25-2012, 10:52 PM   #9
bmorecam
Did the problem go away? Loose gas cap can certainly make evap code pop up but I heard that the early GM direct injected models such as LNF had slew of evap purge solenoid failures. If everything is good after you tighten the gas cap than I guess it was false alarm, but you might want to keep this in mind judt incase it come back.
Sent from my VTAB1008 using Tapatalk 2
Old 04-26-2012, 05:20 PM   #10
2lt2012
My check engine light is still on, I'm going to give it a couple more days and see
Old 04-27-2012, 11:58 AM   #11
bmorecam
leave the negative terminal off from the battery in the trunk for about 30 minutes and see if the CEL come back on. Any rough idle?
Old 04-27-2012, 02:49 PM   #12
2lt2012
The idle is normal for the most part, Tho sometimes it does feel a little weird at idle, I thought it might be cause I have aftermarket exhaust and no intake to breath better...
Old 05-11-2012, 03:10 PM   #13
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Does this work on OBD-2 cars? I always thought the newer ECUs had to be cleared whenever a code appeared since the code is stored inside the ECU.
BlaqWhole is offline   Reply With Quote
Old 05-13-2012, 01:18 AM   #14
Judge
Judge's Avatar
Drives: 2011 L99 Camaro SS
Hey guys as soon as you get aftermarket headers or exhaust the check engine light should come on; i have the same problem
That is because the cars ecu detects a change in air calibirations, and it thinks something is wrong with the car; i believe this can be fixed with a custom tune
Judge is offline   Reply With Quote
