Old 04-25-2012, 01:17 PM   #1
CPDSS
Drives: 2010 SS M6
Fast LSXR Intake+Nick williams 102MM Throttle Body
is anyone here running the Fast LSXR 102mm Intake and the Nick Williams 102mm throttle body with the only other mods being a Cam, Headers, CAI and Exhaust???? any significant gains in hp/tq
looking at these two items to go with the other items listed but not sure if its worth the apporx $1500 worth of parts(intake and throttle body).
CPDSS is offline   Reply With Quote
Old 04-25-2012, 02:11 PM   #2
SC2150
Add some good big-valve CNC heads and you will get the most out of that combo.
Old 04-25-2012, 02:18 PM   #3
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Looking at my results I would say the combo is worth little to nothing...my numbers are nothing special compared to some others who didnt use the 102/102 combo.
I have ~20 rwhp over the average cam only g6x3 car and I have heads. I would think that ~20hp is all from the heads.
I honestly wouldn't waste the money if I had to do it over again. Have sc2150 port your stock TB and have another reputable place port your stock manifold if you really need to mess with it.
376 cubes just isnt enough to use a 102mm inlet NA. If you plan on doing a SC I have read that the 102 TB can be worth some very good gains...15-20hp I believe.
ULTRAZLS1 is offline   Reply With Quote
Old 04-25-2012, 02:25 PM   #4
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Damn Troy, you beat me to it. I was searching for your build thread and up you pop, lol.
http://www.camaro5.com/forums/showthread.php?t=211958
Check out his build thread here.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 04-25-2012, 02:28 PM   #5
ULTRAZLS1
ULTRAZLS1's Avatar
T.
Old 04-25-2012, 02:35 PM   #6
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
+1
I although do feel that the 102mm intake is helpful if your doing a big cam. I lost nothing down low even with a big cam which I attribute in my own mind somewhat to the intake. I have seen a few builds where they didn't have the intake manifold and lost a bit in low rpm range hp/tq wise. Overall i'd say on its worth ~10rwhp at best.
VanquisherSS is offline   Reply With Quote
Old 04-25-2012, 02:48 PM   #7
BLACK10
BLACK10's Avatar
That setup on the camaro also requires an aftermarket idler pulley which is another $100+
Old 04-25-2012, 03:12 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
And dont forget a different belt
Old 04-25-2012, 03:31 PM   #9
VanquisherSS
Right . Its only like what $20 bucks?
Old 04-25-2012, 04:00 PM   #10
ULTRAZLS1
ULTRAZLS1's Avatar
Something like that...I didnt buy it before hand, the shop had to buy it before the car could be finished. I thought the tensioner could be adjusted to make the existing belt work...so it was a nice surprise lol.
Old 04-25-2012, 08:11 PM   #11
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I think the combo of FAST 102 and NW 102 TB is probably worth about 15 RWHP. Thats what I picked up after tuning them in. This is with a build just like Troy's, minus the TSP heads. I don't know if it was the tune, but low rpm driving and throttle response improved over a VMax ported TB.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-25-2012, 08:13 PM   #12
blake-b
blake-b's Avatar
Drives: 2009 ZR1
It didn't on mine. I bought my LSXr used and when I got it, it was supposed to have (according to the directions) a large washer (spacer) to ever so slightly push the tensioner pulley out just enough...
I called Comp and they gave me the dimensions and I found one that worked. There isn't much space between the pulley (idler) and the TB, but there is space, probably the thickness of a quarter or so. I never measured it.
I haven't started the car yet so it might jump off but by eyeballing it, it appears to line up nicely enough. I cannot remember the thickness of the washer but it wasn't anything extreme, basically a normal thickness washer. The diameter of it was what was needed to go behind the idler pulley and the center hole big enough for the stock bolt to go through.
Before I discovered I could use the stock idler, I bought the necessary belt to use the Katech idler. I couldn't remember which was which so I tried for several minutes to get the "shorter" belt on before I remembered it might be the short belt. I then grabbed the stock belt and it went right on.
Old 04-26-2012, 12:40 AM   #13
BLACK10
BLACK10's Avatar
Just be sure to keep an eye on it for it making contact with the tb. If you are in and out of the throttle the tensioner moves quite a lot!
Good luck!
Old 04-26-2012, 01:31 AM   #14
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Good luck!
I had to go check. With the tensioner all the way left (tight-as you face the car looking into the engine bay) there is slightly more than the thickness of a quarter (.25 piece). With it all the way right (loose), it is barely (think thickness of a postcard) not touching it. The tightest point is about in the middle of the pulleys movement. If I apply any backward movement (towards rear of car) when it is in the middle of its range of motion, it will touch. Hopefully, this won't be a problem as the plastic pulley should get clearanced if it touches. I will keep an eye on it and go to the Katech if necessary seeing as I already have a belt for it...
I took a couple of pics to show the clearances.
