Old 04-25-2012, 11:13 PM   #1
Amychelle
Drives: 2010 Synergy Green Camaro
Help! Tire Pressure Monitoring System is confused
My TPMS is confusing my passenger side tires. When I put air in my front tire today, the TPMS said the PSI went up in the back tire. ( Yes, I checked it with a regular gage) I tried making the the car relearn the the PSI, but it didn't work. Anybody know what the problem is? Or, do I need to take it to a dealer and, if so, what will it cost?
Thanks!
Amychelle is offline   Reply With Quote
Old 04-25-2012, 11:27 PM   #2
nytrorcr
nytrorcr's Avatar
Drives: I.P.C. 2SS vert, 21 wheels
Location: Cookeville, TN but Just above Atlanta, GA for now
Have you rotated your wheels lately? I think the dealer has to help it relearn where the frt and rear and left to right.......at least that is the way it was on my 2011 2ss when I got the new wheels.
2011 2SS Convertible A6
nytrorcr is offline   Reply With Quote
Old 04-26-2012, 01:16 AM   #3
bigdog96z
bigdog96z's Avatar
Drives: '13 Avalanche & 2018 1SS/1LE SW
TPMS setting
This is from my 2010 owner's manual:
The TPMS matching process is
outlined below:
1. Set the parking brake.
2. Turn the ignition switch to
ON/RUN with the engine off.
3. Go to the TPM vehicle
information screen on the DIC.
See
Driver Information Center
(DIC) on page 4-27
. Press set to
relearn the sensors. The horn
sounds twice to signal the
receiver is in relearn mode and
Tire Learning Active message
displays on the DIC screen.
4. Start with the driver side
front tire.
5. Remove the valve cap from
the valve stem. Activate the
TPMS sensor by increasing or
decreasing the tire’s air pressure
for 10 seconds, or until a horn
chirp sounds. The horn chirp,
which can take up to 30 seconds
to sound, confirms that the TPMS
sensor identification code has
been matched to this tire position.
6. Proceed to the passenger
side front tire, and repeat
the procedure in Step 5.
7. Proceed to the passenger
side rear tire, and repeat
8. Proceed to the driver side rear
tire, and repeat the procedure
in Step 5.
9. After hearing the confirming horn
chirp, for the driver side rear tire,
the horn sounds two more times
to signal the tire learning mode is
no longer active. Turn the ignition
switch to LOCK/OFF.
10. Set all four tires to the
recommended air pressure
level as indicated on the tire
and loading information label.
11. Put the valve caps back on the
valve stems.
The tires air pressure will not
appear on the screen until you start
driving the vehicle.
2018 1SS/1LE Summit White
Cold Air Inductions CAI
JLP Catch Can
bigdog96z is offline   Reply With Quote
Old 04-27-2012, 04:41 PM   #4
TRABlackCamaroSS
TRABlackCamaroSS's Avatar
Drives: '10 Blk Camaro SS/'08 Blk Silverado
Take it to the dealer/I just put new wheels,tires & sensors on my SS; took it my dealer & he fixed it in about five minute with their relearn wand....
TRABlackCamaroSS is offline   Reply With Quote
Old 04-27-2012, 09:09 PM   #5
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
You're lucky!
I went to discount tire to let them use their wand but for some reason the car never took a liking to the new tire pressures. Actual tire psi is 37 but dic says 33 after the relearn. He said he could trick the dic but it would become a liability issue.
Can Chevy fix this for me? Anybody?
edgehead2000 is offline   Reply With Quote
Old 04-28-2012, 12:26 AM   #6
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I think it's common for the TPMS to read lower than the actual pressure. I had my tires filled to 38# yesterday and immediately after the DIC showed 33, 34, 33, and 35#.
There is also differences between guages, so I don't think you're ever going to find perfect agreement between the TPMS and guages.
Meh
My 5th is offline   Reply With Quote
Old 04-28-2012, 09:32 AM   #7
edgehead2000
Drives: Nemesis
At 'My 5': that's a bummer. Why would they do that? It just a little annoying I guess.
Old 04-28-2012, 12:16 PM   #8
Tom D
Tom D's Avatar
Drives: 10 Camaro SS/RS RJT
I just put new wheels, tires and TPMS and mine read perfect after relearn procedure in manual. I did have to drive it first to get it exact though. Right after relearn it showed one at only 22. After driving like manual says it was exactly the same. One thing though. It seemed like it took a lot of air released to learn it. Manual says it could take up to 30 seconds of letting air out. So be patient and wait for the beep. I counted each one out and one even took 35 secs. Good luck.
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
Tom D is offline   Reply With Quote
Old 04-29-2012, 12:05 PM   #9
MiSS1LE
MiSS1LE's Avatar
Drives: 2014 1LE & 2014 C7
I relearned mine following owners manual Posted above
After letting air out for 10 seconds and the waiting minimum of 30 seconds after the then horn sounded repeated process as stated above and last wheel horn sounded twice the all was good !!
Drove around my subdivision worked great !!
MiSS1LE is offline   Reply With Quote
tire pressure, tpms
