Old 04-29-2012, 08:25 PM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
torque specs for Kooks LT headers
As the title says I'm looking for the correct torque specs to retighten the bolts. (I did use the search function but couldn't find the specs)
I just discovered a small header leak on my Kooks LTs (Driver side). I reused the factory GM gaskets and bolts. Can I just retighten the bolts or do I need to replace the gaskets?
mike.nite is offline   Reply With Quote
Old 04-29-2012, 08:52 PM   #2
js19racer
js19racer
js19racer's Avatar
Drives: 2011 Camaro 2SS/RS
Put a NEW set of GM gaskets on it. Bolts are fine, Put a little anti-seize on the threads when reinstalling.
js19racer is offline   Reply With Quote
Old 04-29-2012, 11:08 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
This.....and 18 ft/lbs if you want to retorque. I would just do the old "good-n-tight" method. Sounds like you mostly need a new set of GM gaskets.
Build Journal
Old 04-30-2012, 12:38 AM   #4
dragon22
Drives: 2010 Camaro 2SS/RS SIM
One trick we used years ago with the gaskets that come with the headers...
We used to soak them in water overnight, install them while wet, torque the bolts slightly more than spec and fire up the engine. Afterward you have a gasket that looks like a metal gasket.
But yes, the spec on the bolts is 18 ft/lbs final torque.
The manual says to use thread loc though.
dragon22 is offline   Reply With Quote
Old 04-30-2012, 02:33 AM   #5
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Do not use thread loc. Use anti-seize 18ft/lbs drive it a few times and retorque.
Slickcas is offline   Reply With Quote
Old 04-30-2012, 12:54 PM   #6
Fast Motorsports
Drives: Camaro
We always use new GM gaskets when doing header swaps. Also, we replace the stock header bolts with flange headed bolts that are 25mm long. This is done since most stock bolts will bottom out in the head before the flange is actually torqued down and you will get small leaks.
Fast Motorsports is offline   Reply With Quote
Old 04-30-2012, 12:59 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
my torque wrench doesn't even go down to 18 ft/lbs. I had to put it at 20 ft/lbs
Click to view my build thread
Old 04-30-2012, 04:56 PM   #8
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
I would never put antiseize on anything going in the heads. The Kooks headers do come with new stainless hardware.
I always say "hand tight'. The point right before it requires a little muscle.
MarylandSpeed is offline   Reply With Quote
Old 04-30-2012, 05:08 PM   #9
mike.nite
mike.nite's Avatar
Wow - thanks guys for all the help! This place is just amazing..
Here's what the leak looks like (I have Kooks 1 7/8):
Do you think my gasket is damaged? Do I realy need to replace it? My plan was this:
- Clean everything and retighten the bolts. Then check back after some miles. If everything stays clean I don't need to replace the gasket if there's again a leak I'll order a new one.
Old 04-30-2012, 09:31 PM   #10
OVRKILL
OVRKILL's Avatar
Drives: 01SS
^^ new gasket.
'01SS - RHS 460....fed by 8 little throttle bodies
Kinsler / Fikse / RHS / Mast / MWC / Kooks
OVRKILL is offline   Reply With Quote
Old 04-30-2012, 09:42 PM   #11
MarylandSpeed
Where did you get those? It has been a while since I opened a box, but kooks normally are not welded all the way around like that. Do they have a Kooks badge. I could be wrong, just curious.
Old 04-30-2012, 09:47 PM   #12
mike.nite
mike.nite's Avatar
Sorry - those are not mine. But the leaking spot looks allmost the same.
So I definately need a new gasket either way?
Old 04-30-2012, 09:54 PM   #13
js19racer
js19racer
js19racer's Avatar
@Marylandspeed, Why not? Steel and aluminum don't mix. They have different expansion rates, so why not use anti-seize to keep it from gulling??
Old 05-01-2012, 01:32 PM   #14
mike.nite
mike.nite's Avatar
So I definately need a new gasket either way? Any chance I can keept the installed gasket?
