Old 05-03-2012, 01:52 PM   #1
oakaro68
oakaro68's Avatar
Drives: 2015 Camaro Z/28
Looking for blower cam that's easy on springs
Sponsors/Members,
I'm doing some cam research and would like to find a cam that has a mild chop at idle, makes great mid-range power, and works well with a roots style blower. I would like the lift profile to be MODERATE as I do NOT want to replace my springs every 25K (35K doesn't cut it either) miles. It's a daily driver and will see drag time maybe 1 time a year and would like to do a road course or 2 without worrying about spring breakage.
Jannetty - I like your smooth idle blower cam but it seems like is has a very agressive lift profile (although I don't know the EXACT lift) but the sound is what I'm looking for (I know it makes great power, which is important)
Any suggestions would be greatly appreciated.
oakaro68 is offline   Reply With Quote
Old 05-03-2012, 03:20 PM   #2
4ty6&2
Drives: slow
just go with the zr1 cam then. you dont have to change anything and most people see 35 rwhp gain or so.
4ty6&2 is offline   Reply With Quote
Old 05-03-2012, 03:59 PM   #3
oakaro68
oakaro68's Avatar
I want something with more duration and more agressive idle than the zr1 cam though
Old 05-03-2012, 04:15 PM   #4
Robd
Robs SS
Robd's Avatar
Drives: 2011 camaro ss synergy
Heres a vid of mine running Check out this video on YouTube:
Sent from my iPad
[COLOR=lime]my kinda going green POWER 605 RWHP powered by maggie chrome tsv 2300 supercharger,ar long tube headers high flow cats b and b exhaust ,roto fab intake ,lingenfelter cam , upgraded sc reservoir ,Comp cams
performance valve springs, Comp cams Titanium retainers,Heavy duty valve locks,MSD ignition wires, Kool Sox heat resistant heat sleeves , Larger fuel injectors, high flow fuel rails,American racing rims ,hurst short throw shifter,led footwell and grille lighting,pfadt suspension upgrades
Robd is offline   Reply With Quote
Old 05-03-2012, 04:16 PM   #5
oakaro68
oakaro68's Avatar
I'll listen to it when I get home, what cam are you running?
Old 05-03-2012, 04:25 PM   #6
Robd
Robs SS
Robd's Avatar
Lingenfelter gt9 is cam I got around 330 in video is decent for sound and idle
Old 05-03-2012, 04:54 PM   #7
oakaro68
oakaro68's Avatar
330..?
Old 05-03-2012, 04:57 PM   #8
old motorhead
Drives: Maggie blown LS3 vette
.629 and .656 lift. Hardly fits his "moderate lift" requirement. Most any current design cam lobe is going to have lift in the .600 area for most any cam upgrade. You can use some of Comp Cams' older designs, but I'd question if the lower lift is really saving your springs. Comp has an "Extreme RPM low lift" series of lobes that might fit what you're wanting. Depending on the duration desired, the lift isn't much different than a stock LS3's.
old motorhead is offline   Reply With Quote
Old 05-04-2012, 01:31 PM   #9
oakaro68
oakaro68's Avatar
yeah the lift is too much for what i'm looking for on that cam, thanks though.
Old 05-04-2012, 01:52 PM   #10
oakaro68
oakaro68's Avatar
what do you guys think of the spring longevity on the jre smooth idle blower cam?
Old 05-04-2012, 03:10 PM   #11
SC2150
I have 2 mild cams that would work...but neither is an ideal FI grind:
.585/.585 238/238 on a 113
.578/.578 229/229 on a 116
$250 each shipped if interested. Better than stock but both are NA grinds.
Old 05-04-2012, 03:11 PM   #12
chevyboy221
chevyboy221's Avatar
Drives: 2015 SS L99
not tring to be an ass but i think what you are looking for isnt out there. you want a cam with lift you can hear but you dont want the maintinace that goes with it. get a ZR1 cam and dont worry about it or get a bigger cam and have the maintnace that goes with it
chevyboy221 is offline   Reply With Quote
Old 05-04-2012, 03:19 PM   #13
oakaro68
oakaro68's Avatar
the lift isn't exactly what makes it lope. the gm hot cams only have .525 lift and sounds good because it's on a 112 LSA and has more duration. Not good for FI though...
Old 05-04-2012, 03:25 PM   #14
Blu808
Blu808's Avatar
Drives: Hankook Formula Drift Camaro
Send a message via AIM to Blu808 Send a message via Yahoo to Blu808
When upgrading the cam, especially on an FI car, its important to change out the springs every 100 hours of driving to be on the safe side. Have you looked at the G6XB cam? We stock this cam and it makes great mid-level power.
We installed a cam kit, which includes the camshaft, cam springs, pushrods, retainers, etc, and the car made 584whp/590tq with a maggie, long tube headers, and the OD cog drive.
PM or call us and we can get you a great price on the G6XB cam!
Blu808 is offline   Reply With Quote
