Old 05-04-2012, 05:18 PM   #1
mcapple
Drives: 2011 Camaro 2LT
Unhappy 2LT misfire
I have a 2011 2LT camaro. It's been the 8th or 9th time it got misfire. The car has no aftermarket parts. Error code is P0301 every time. The dealership changed all spark plugs(they are rich fouled, I think it's not normal considering the car only done 16000km) and injector(looks clean) in cylinder 1. I call GM Canada for help. They ask me to go to the dealership again.
Condition when misfire occur: I am in 6th gear, 100km/h, 2000rpm, as soon as I take my foot off the throttle, car still in 6th gear, misfire happen.
I ask the technician if he see a lot deposit on the intake vale. He said is fairly clean.
I'm not sure what they can do to fix it. Any suggestions? Go to a different dealership? They run the same test anyway.
I guess they should change the ECU? maybe the engine?
mcapple is offline   Reply With Quote
Old 05-04-2012, 05:23 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
The only time I got a miss fire was after i took my car out of storage and was running on the gas that I had stored(that had stabil in it) I ended up putting in dry gas and have yet to have it happen again.
kjkjr27 is offline   Reply With Quote
Old 05-05-2012, 06:56 PM   #3
JCO2185
RIDING ON AIR
JCO2185's Avatar
Drives: 2010 2LT/RS Summit White
im having misfire codes as well.
--John--2010 Camaro 2LT/RS, Summit White
Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels
JCO2185 is offline   Reply With Quote
Old 05-05-2012, 07:00 PM   #4
bmorecam
you guys need a reflash. I talk to my service manager and he gave me the whole run down. there's nothing wrong with your car, but of course unless its something else you guys diagnosed that's causing the misfire. Its a simple glitch in the ecu that affect some bosch e69 from 2008 to 2011. There's a TSB for this problem.
Old 05-05-2012, 11:25 PM   #5
mcapple
Thanks. I'll let the service manager know this. Is there a name for the TSB? The dealership asked help from GM and opened a TEC case for the problem. But GM says they never have this kind of problem before, I guess they don't know about the TSB.
Old 05-05-2012, 11:31 PM   #6
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
I only had a misfire once. It was on a dyno up in Cincy.
PieNsky is offline   Reply With Quote
Old 05-06-2012, 11:45 AM   #7
SC2150
That and the oil ingestion causes the plugs to foul easier.
Old 05-07-2012, 10:53 AM   #8
mcapple
I told the dealership about reflashing computer. They said that they need to follow the instruction from GM since GM is paying the cost. And they can't not guarantee when it can be fixed. Is there anything I can do to push GM reflashing the ECU?
Old 05-08-2012, 04:44 PM   #9
mcapple
The dealership says they will change the serpentine belt
Old 05-08-2012, 06:46 PM   #10
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
What the heck does the serpentine belt have to do with misfires? Sounds like you need to find a new service department if you ask me.
ChadG is offline   Reply With Quote
Old 05-08-2012, 07:19 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Dealer knows best
FSP tuned: 377/389
Old 05-08-2012, 09:27 PM   #12
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Maybe your missing the faa-lan-gee. Those things are really important.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 05-09-2012, 05:40 AM   #13
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
have you tried swapping your coils around to see if the misfire changes cylinders?
hapisok is offline   Reply With Quote
Old 05-10-2012, 12:50 AM   #14
mcapple
yes, switched cylinder 1 and 6 coils, cylinder 1 still has the p0301 code
