NJ Camaro 22
Drives: 2016 Camaro 1SS M6 Join Date: Jan 2011
HELP!
What bolts need to be taken off in order to install the MACE 25mm insulator? I cannot get the intake manifold off for anything!
NJ Camaro 22
bump
Always bet on Black
Drives: 2011 turbo LS, 2012 f 150, Join Date: Nov 2010
Make sure you removed the two bolts in the back if you have do a search there are some nice write up on install. Would post you a link but cant with tapatalk.
Sent from my iPad using Tapatalk HD |
ill post the link to the black iceolator should be the samee
you need a 13mm flex wrench to get the back bolts off http://www.camaro5.com/forums/showthread.php?t=203645 hope that helps off topic..are those havoc black chrome wheels? i would love to see them in person |
NJ Camaro 22
thanks so much! alright ill have to go buy one of those, and yea they are ill pm you if you want to meet up or something
#6 |
did you end up getting it installed?
#7 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
there's one on the front, 4 in the middle and 1 all the way in the back. 13mm or 1/2" socket should do.
#8 |
NJ Camaro 22
went out and bought a flexing socket wrench and that wont do it, i could not find a 13 mm flex wrench. I guess I need that to do it
#9 | |
In fact this is the one I got.....just a note, it won't be a quick job to get the back bolts out, took about 20 mins for me to take them off and put them back in....so keep turning that wrench wee bit each time ![]() http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
I am by no means a mechanic. What is the skill required to do this? What's the possibility of screwing things up?
#11 |
NJ Camaro 22
Yea I need to order a flex wrench not a flexing socket wrench. The two 13mm bolts in the back could not be in a worse spot.
@Rangore, I'm 18 and by no means a mechanic at all either, doesn't seem like you need to much skill, just the right tools IMO |
#12 |
NJ Camaro 22
I tried autozone for the flex wrench, called a custom car shop for help on the install and they're 3-4 weeks back up. So I'm going to try sears and pepboys for the tool and hopefully someone has it
#13 |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
sears is the place to go. you can buy the single flex head wrench for like $20 or a set for $40ish. id get the set, i've found they are the most useful tool in my box so far.
#14 |
Let's go Rangers!
Do you have a harbor freight nearby?
