Old 05-07-2012, 01:07 AM   #1
RSloth
[COTW- Never!]
RSloth's Avatar
Drives: Slothy; Sloth-like
Engine Cover Paint
Im looking to paint my engine color silver(and or) white
but was told I need a high heat resistant paint to do it.
anyone know of any brands? or places to order these paints?
Or just general info on painting my cover?
Help?
RSloth is offline   Reply With Quote
Old 05-07-2012, 01:32 AM   #2
v6
v6's Avatar
Drives: 2012 45th 2LT RS
I just went to lowes and got primer that stick to plastic and then the Rustoleum High Heat paint. might want to try online though because selection isnt that great in a store especially for a proper red color. I painted mine myself. if you want it so be smooth then sand the cover and if you want it to be. let me know what you need help with or what questions i can answer. im no painting expert but i did it myself and it looks great.
v6 is offline   Reply With Quote
Old 05-07-2012, 01:47 AM   #3
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
walmart, krylon fusion no primer, just light sanding and alittle greas and wax remover.[IMG][/IMG]
[IMG][/IMG]
after a year and a half and some stickers later.
[IMG][/IMG}
the stickers have been on for about a year, and still not peeling off.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 05-07-2012, 07:52 AM   #4
Ladybugsmom
Older than I look....
Ladybugsmom's Avatar
Drives: 2010 VR Camaro 2SS/RS LS3
I was looking around Autozone yesterday, and they have a whole bunch of high heat paints. A lot of colors, many brands, most of them say they're specifically for engines.
High Heels and Fast Wheels!!
Ladybugsmom is offline   Reply With Quote
Old 05-07-2012, 08:04 AM   #5
Broffermoon
Broffermoon's Avatar
Drives: 2010 Camaro SS RS
Washed down with mineral spirits followed by alcohol, dried thoroughly, sprayed with Krylon, 5 coats. Love the results. Did the fuse box cover as well, 2 cans.
Only those who will risk going too far can possibly find out how far one can go. --T.S. Eliot
Broffermoon is offline   Reply With Quote
Old 05-07-2012, 08:11 AM   #6
RScamaro30
RScamaro30's Avatar
Drives: Like I Stole It
Rust-Oleum White Heat-Resistant Spray Paint (at AutoZone) used it before, works well! http://www.autozone.com/autozone/acc...fier=69499_0_0_
RScamaro30 is offline   Reply With Quote
Old 05-07-2012, 09:25 AM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
All I use is Krylon, and shoot it with white first as a base coat for bright colors.
Old 05-07-2012, 09:51 AM   #8
Secret Squirrel
Secret Squirrel's Avatar
Drives: 1965 Chevelle Malibu
I also went to lowes and got the Rustoleum spray. I did satin black. It has held up perfectly fine. Only issue I had painting my cover was finding a tape that would stick to the plastic. I am not exactly experienced in DIY paint jobs, but after some light sanding, and a good cleaning, I was able to make it work, and it looks fantastic. Much better than spending 150+ on a new painted cover.
Secret Squirrel is offline   Reply With Quote
Old 05-08-2012, 09:04 AM   #9
agkelly73
agkelly73's Avatar
Drives: 2016 SS Convertible
When I originally did my engine cover, I used some everyday paint in silver and hit it with a clear coat. However, after a few months of the heat, it started to yellow. I resanded and this time I used Duplicolor Silver for GM cars and their clear coat. Had it on for the past year and a half with NO issues with color yellowing. Just my experience with it though.
agkelly73 is offline   Reply With Quote
