Old 05-08-2012, 04:06 PM   #1
cris
Drives: 2010 Camaro SS L99
launch control for L99
I need to know if the auto trans have this system???? I have a L99 and I will like to know is this model have this to ore only the LS3 camaro.
thanks
cris is offline   Reply With Quote
Old 05-08-2012, 04:07 PM   #2
SB09
SB09's Avatar
Drives: 2012 SS/RS M6 AGM
Only the manual's have this feature.
Pin it to WIN it!
SB09 is offline   Reply With Quote
Old 05-08-2012, 04:14 PM   #3
cris
thanks ....
Old 05-08-2012, 05:07 PM   #4
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
The auto kind of has it...
If you're not tuned... (it appears some tuners remove this)
if you put it into competitive mode...
if you apply the brake...
if you quickly push the accelerator to the floor...
it will hold the RPMs at 1400.
Then you can just lift off the gas and go.
Source: http://www.camaro5.com/forums/showthread.php?t=120293
It works on mine, but it does seem to occasionally hit the rev limiter just before it shifts into 2nd, which I find odd.
Last edited by Three of Swords; 05-08-2012 at 05:10 PM. Reason: Edited to add link.
Three of Swords is offline   Reply With Quote
Old 05-08-2012, 05:30 PM   #5
cris
Thanks
Old 05-11-2012, 10:17 PM   #6
Patrick G
Drives: 2009 Pontiac G8 GT
You can modify the traction control to suit your driving habits through custom tuning. If you have patience, you can alter the multiple tables to allow the tires to haze, but not overwhelm the pavement. As you add power, the factory settings become ineffective.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Old 05-11-2012, 11:51 PM   #7
SS King
SS King's Avatar
Drives: a Panty Dropper
L99 has NO Launch control . I've tried what you guys are saying and all I get is a big smoke show
SS King is offline   Reply With Quote
Old 05-12-2012, 12:05 AM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by SS King View Post
L99 has NO TC. I've tried what you guys are saying and all I get is a big smoke show
Both LS3 and L99 have traction control...
Pretty Sure what Patrick G meant was TM or Torque Management...
Edit: nope... he's talking about traction control... and he is the guy who would know...
Old 05-12-2012, 12:15 AM   #9
SS King
SS King's Avatar
OOPS I meant to say No Launch control. L99 does not have it. Yes it does have tc
I'll edit that post
Old 05-12-2012, 12:53 AM   #10
Three of Swords
Don't know what to tell you. I do it all the time, exactly as I said in my post, and it works fine. I'm not tuned or modded beyond a cold air intake.
I can think of three possibilities:
a) Are you tuned yet? Based on threads you started, you have been looking to do it. If so, that might be the issue.
b) Are you pushing the gas to the floor quickly? Going slowly won't engage the rev limiter or whatever it is.
c) Are you in competitive mode? Turning off all the nannies does not do this. Turning off just traction control does not do this.
Old 05-13-2012, 05:29 PM   #11
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I'll edit that post
LOL... that makes sense...
Old 05-13-2012, 05:49 PM   #12
white ZL1
Drives: none
I think what you're seeing is the Stall Torque Management. It enables at 1500rpm and disables at 1300rpm...hence why you see ~1400rpm when you do this.
white ZL1 is offline   Reply With Quote
Old 05-13-2012, 06:11 PM   #13
Patrick G
This is correct. Fortunately, this threshold is totally tuneable and can be raised or lowered to suite your traction/launch conditions (through a custom tune of course).
