Old 05-09-2012, 03:09 PM   #1
blove-si
Drives: 2010 Black 2-ss Camaro
looking to do a fast intake on my 2010 camaro
All,
I am looking to go to a fast intake on my 2010 camaro that has a pretty big cam , L99 to LS 3 conversion, new lifters, push rod, ported and polished head work, a lot of top end work. what are you all using for a throttle body. There aren't a lot of options out there and I heard there is tuning and drive-ability issues.
blove-si is offline   Reply With Quote
Old 05-09-2012, 06:23 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you feel you have to have the Fast 102 manifold, you'll need to get the NW 102 TB to match. This one and possibly the BBK 102 are the only ones that will work since they retain the factory cableless mechanics. While your stock TB will fit, it doesn't make sense to choke the bigger intake with it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-09-2012, 07:35 PM   #3
TRIPWIRE
Chillin Like a Villain
TRIPWIRE's Avatar
Drives: 2013 2SS Blue Ray Metallic Dusk Ed.
with you other mods you should see some decent gains with it and for a throttle body i would def recommend a nick williams 102mm throttle body
TRIPWIRE is offline   Reply With Quote
Old 05-09-2012, 07:54 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Nw 102 hands down, just don't use your stock tb
Old 05-09-2012, 09:32 PM   #5
MikeOD
Drives: 2010 M6 2SS
Honestly...you're not going to hurt anything with the stock TB if you don't feel like spending the cash on both at once...my car has had ported heads/ported fast 102 and a big cam for 6 or 7K miles now...and I haven't bought the NW102 yet. I agree it's a good idea to get it, and I fully intend to myself...but it's not the end of the world.
I think I'll probably gain 5-10 HP at MOST when I swap...not a huge deal...but why go the extra mile on everything else and not upgrade that part?
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
