Old 05-10-2012, 09:55 AM   #1
nmalik3000
Drives: 2008 C6 z51 mn6
Who's running over 600rwhp on the stock motor without issue?
Hello everyone. I have a 2008 corvette coupe (LS3 motor, 6 speed manual trans) that ECS supercharged last August with a TVS2300 supercharger making 8.7lbs of boost, callaway honker cold air intake, and American racing headers with high flow cats. The car put down 578rwhp and 526rwtq and has been a total blast to drive!
However, just like everyone else, I have got the need for more power! ECS is recommending that I go with their small blower cam plus methanol injection to make another 80-100 rwhp safely, so I should be around the 650rwhp mark...
I would like to hear everyone's opinion with regards to the safety of running this much power on the stock ls3 motor? Are many people on this forum running at this power level without issue? I would love to hear from you guys that are making big power safely on the stock motor.... or is this just too much power to be had safely?
Thanks guys,
Raj
nmalik3000 is offline   Reply With Quote
Old 05-10-2012, 11:37 AM   #2
camslambam
Drives: 2010 SS, 06 SRT10 Ram
I am.
camslambam is offline   Reply With Quote
Old 05-10-2012, 12:14 PM   #3
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Originally Posted by camslambam View Post
I am.
+1
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 05-10-2012, 12:21 PM   #4
AintQik
Drives: 67 Pro-Tourer, 12 SS
You won't have issues with ECS. I know of many set ups making north of 600 and still together. Flukes aside, ECS know what they are doing.
AintQik is offline   Reply With Quote
Old 05-10-2012, 12:23 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks guys,
Raj
Better than 50% of my supercharger Customers are at or above 650 RWHP on stock long blocks.
Put your Trust in ECS they got it handled.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-10-2012, 12:25 PM   #6
Sales @ ECS
Sales @ ECS's Avatar
Drives: 2011 CG 2SS
Thanks guys,
Raj
Octane, octane, octane, and tune... Those are the 4 things (Yes I know actually 2), that will keep your motor together. We have countless (Honestly, I couldn't tell you how many because there are hundreds upon hundreds) of LS3 motors that are 600rwhp +. We have hundreds in the 700+ range and 800+ rwhp range on stock bottom end.
Its all in the tune and the octane.
Sales @ ECS is offline   Reply With Quote
Old 05-10-2012, 01:52 PM   #7
NoMercy
NoMercy's Avatar
Drives: 2012 ZL1
Dyno numbers are in my sig. I am not running meth and this was on 93 octane. No problems at all other than bald tires!
Magnuson TVS 2300, 16% OD rear pullies(stock 3.8 on front jackshaft), Vector Motorsports 2.5 cam, hardened push rods, titanium retainers, patriot gold double springs, Dynatech 1 7/8 Longtube headers, gutted cats, F.A.S.T. 90lb. injectors, Lonnie's double pumper fuel pump, ZR1 Plugs, Airade cai, HP tuned by East Texas Musclecars. 660 rwhp / 611 rwtq
NoMercy is offline   Reply With Quote
Old 05-10-2012, 03:19 PM   #8
EvoWake
SSTOCK
EvoWake's Avatar
Drives: 2010 Camaro 2SS/RS
612/580 for ~2500 miles and 8 or 9 passes on DR's at the strip. no issues.
2010 Camaro 2SS/RS
EvoWake is offline   Reply With Quote
Old 05-10-2012, 03:23 PM   #9
nmalik3000
Thanks for all the responses guys. Keep them coming. I like seeing everyone's setups on the stock motor.
Old 05-10-2012, 03:31 PM   #10
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
616, running fine.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 05-10-2012, 03:45 PM   #11
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I was at 637whp for about 6000 miles then pulley'd down added meth, boost was about 12psi. Drove it a hard an add'l 2000 miles (just under 6 gallons of meth in those miles) trying to break my Gforce drive train components.
Did not break them but broke a piece off my top ringland on the #5 cylinder. See the link to my thread about it. I drove the crap out of the car not caring if it grenaded since my new LSX motor was already being built. I knew the stock bottom end would not last, it was kind of an experiment. I blended 104 sunoco 3 gallons per tank (about 96 octane in the tank) plus ALKY meth kit.
I saw your post over on corvetteforum on this same subject so i know you are familiar with Taylor Simms and Dallas Performance. He did my tune so you know it was an outstanding tune, he is one of the best!
I will sent off the dinky 65# injectors to have them tested. I suspect the #5 is probably bad. at any rate, i was on the limit with these injectors at my power level.
The car still runs, i just dont drive it. Gonna sleeve this LS3 block and forge it to have a spare 427
My HKE built LSX 427 is about 3 weeks from completion then off to Taylor at Dallas Performance for install, custom fuel system return style with triple DW300 pumps feeding ID1000 injectors and Taylor's tune.
Have a back up plan and be prepared for the worst just in case. Do not skimp on the fuel system if you up your boost. Mine lasted quite a while considering the abuse i put it thru and if you look at the chunk missing from #5 its not really that bad. All the other cylinders look good.
http://www.camaro5.com/forums/showthread.php?t=214698
http://www.camaro5.com/forums/showthread.php?t=213076
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-10-2012, 07:51 PM   #12
1 bad azz ls3
1 bad azz ls3's Avatar
Drives: 2010 camaro ss
748 hp. stock bottom end....... meth is your friend............ thanks ted....................
1 bad azz ls3 is offline   Reply With Quote
Old 05-10-2012, 08:29 PM   #13
Bill Waters
Drives: 2011 RS/SS; 1965 Cobra Factory Five
Timely post: MTI racing is finishing an install for me right now. TVS 2300 Magnacharger, Stage 3 cam, ARH long tubes and 3" exhaust, CAI cold air and dyno tune. Here's hoping a stock bottom end is OK!!
I believe the guys at MTI would echo the sentiments on this thread about the stock LS3 being a reliable platform for these additions.
I' m really looking forward to seeing what the dyno shows as my hp & tq. figures.
Bill
Bill Waters is offline   Reply With Quote
Old 05-10-2012, 09:05 PM   #14
BullF-16
BullF-16's Avatar
One thing i have kind of noticed on here. All or quite a few of the big builds in progress or complete are the result of issues with too much pwr on the stocker.
Believe me, i am not one to say dont up the boost/fun factor. Just have a back up plan for a "bigger and badder" FI build if Murphy rears his ugly cranium (not alowed to say "head"). If its not a daily driver, go for it. Just make sure your fuel system is at least 25% over built, thats cheap insurance. YMMV
