Old 05-11-2012, 11:04 AM   #1
997turbo
Drives: CAMARO 1SS 2011
How a stall can do in 1/4mile for a cammed L99?
I recently fitted TSP AFM/VVT-3 cam to my L99.Rest of mods in the sig.
I am running standard stall at the moment and best ET I can get is 12.8@114.2mph , this with 18"+295 DR ,best 60" I can do is 2.29..its pretty bad.
I am getting a 2800 stall fitted soon,how this will improve my ET?
Also will an aftermarket stall shift faster than standard stall in all 6 gears? My standard stall now shift like xxit with the vvt cam..especially 1-2 and 2-3,during the shifting it bucks a bit and delayed the time.
thanks for your advice!
2011 1SS L99 , Tsp afm-3 cam,2800 stall,K&N CAI,KOOKS 1/78 LT,CATLESS+H-PIPE,SLP UD PULLEY,MSD WIRES,V-MAX TB,JRE TUNE
997turbo is offline   Reply With Quote
Old 05-11-2012, 11:10 AM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Sounds like you need some work on the tranny tune. A stall is going to be one of the best bangs for the buck you can get. Looks like you need to work on the launch some. Tire pressure etc.. Working on getting that 60 down is the best thing you can do at the moment.
JLE58 is offline   Reply With Quote
Old 05-11-2012, 11:44 AM   #3
Supercharged SS
Drives: 2010 Camaro
I gained about .5 with my JRE converter and tranny tune. Well worth the little it costs.
Old 05-11-2012, 12:00 PM   #4
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
What is the stall rpm of an A6 Camaro? Anyone know or tested it?
Hold the brakes and press the gas, see where the rpm stops.
willhe64 is offline   Reply With Quote
Old 05-11-2012, 12:00 PM   #5
fugimo
fugimo's Avatar
Drives: 2010 Camaro SS/RS ABM
With a stall and tune, you can pretty much expect a .5 faster 1/4 mile. With just exhaust (no headers), 3400 stall, tune, cai, trailing arms with bushings, and ported throttle body, my 1/4 mile dropped from 14.3 down to 12.7, this is in 80-90 degree weather also. I have yet to get above 110 mph on the quarter, normally hit around 107-108.
Looks like you are having more of a problem hooking up than anything else. Even with using drag radials, I was breaking them loose on almost every launch, but still able to get 1.7-2.0 60'.
The stall did lower my mpg, but hard to really tell since I like spirited driving, so cannot tell how much it really dropped it, I am getting around 17-18 mpg with 1/2 city driving and 1/2 freeway, 20 miles a day.
Born date 12/18/09
ARK Slant Tip Cat back Exhaust
Ported throttle body
Injen CAI
AAC lighting (Foot well, trunk, interior, RGB Halos, Plasma DRLs, V2 scanner, side markers)
fugimo is offline   Reply With Quote
Old 05-11-2012, 09:33 PM   #6
SSlim
Drives: 2011 Cyber Grey 1SS/RS A6
Same here .5 in my 97 TA with the 2800 vigi and then after I went head and cam I restalled to 3600 and picked up almost another .2 just from the upstall. By far one of the best bangs for the buck on an A6. Haven't done to this car yet, but once the Whip is installed it will be next on the list.
997turbo - Looks like you need to figure out how to get that thing to hook. If you can cut a 1.6 or 7 60' that would easily be a low 12 car. Little differences on the short end pay huge dividends on the far end.
Whipple, GT9 cam, LS3 conversion, ZL1 pistons, ZL1 rods, Circle D converter, Stage 3 trans, Tuned by Pat G, CAI inc, TPS headers, posi mod, Dynomax bullet cat back, VMAX TB, ADM Scoop, RX catch can, Eibach prokit plus, Eurotek Mesh 33 wheels, P13w DRLs, Pioneer/Massive Audio/Vibe/JL interior goodies.
613 RWHP/596 TQ
SSlim is offline   Reply With Quote
Old 05-12-2012, 05:07 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
1st question - Are you pulling slow 60' times because of your cam? That's my guess. You've lots some grunt down low off the line.
Your car is in need of a good transmission tune. The tranny tune will increase shift speeds and firmness.
The converter will not necessarily increase shift speeds and firmness - that's the tranny tune. If anything, the converter may soften up your shifts at higher speeds.
But with proper tuning, the converter will give you the torque you need to get off the line fast. With your mods (cam+ converter, drag radials) you should be 60' in the 1.6x range and running high 11s @ 114 - 115 mph or so.
I would suggest at least a 3200 stall for your setup. If you were F.I. you could go lower, but with your stage 3 cam, I'd go at least 3200.
Old 05-12-2012, 05:29 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
You should post a whole slip and describe how you launch the car.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
