Old 05-11-2012, 05:40 PM   #1
camaross1
Drives: 2012 45th Camaro 2SS
Tuned Camaro
A couple questions. If you get it tuned, is it a one time thing? Will that void any of the warranty? Any place in North carolina that does this? Thanks
camaross1 is offline   Reply With Quote
Old 05-11-2012, 05:43 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yes, it will void your powertrain warranty
Old 05-11-2012, 05:45 PM   #3
stikSS
9691 & 97586
stikSS's Avatar
Drives: 2010 SS, 1999 SS, 1993 Z28
Most dyno tunes can be adjusted as needed depending on the mods you plan or have done, and technically it does void your warranty.... but reality is, it depends on the dealer and what happens to cause a potential problem. One option is, if you have a reputable company or even buy a hand held tuner, you can always take out the tune and reload the factory tune back in and you'll be good to go, most tuners will do that free of charge.
In NC,
There is RPM Motorpsorts, Mayhem Motorsports, There is a place in Charlotte, but don't remember the name. You may want to ask this is the Southeast section
http://www.camaro5.com/forums/forumdisplay.php?f=16
stikSS is offline   Reply With Quote
Old 05-11-2012, 10:22 PM   #4
Patrick G
Drives: 2009 Pontiac G8 GT
You can go with tuning software that does not manipulate the original calibration verification numbers (CVNs) so the modified tunes will still appear as stock. The only issue then becomes the flash counter. Your tunes will appear stock (good for warranty), but the flash counter will be higher than 1.
Honestly, the services techs will typically only check the CVNs when there is a major powertrain failure (engine, transmission). If you're taking your car in for warranty work on your A/C, the chances are almost nil that they would ever bother looking at your CVNs. That's a time consuming process and the dealer is looking to turn the job around quick.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
