05-12-2012, 04:00 PM | #1 |
Drives: 2019 GT350 Join Date: Jan 2011
Help me launch this car.
Hit the local 1/8 mile last night. Conditions were not too bad but there was a low level fog around the track.
I just could not get the car to 60' for the life of me. I am running NT05Rs as well. Here are my rather disappointing results as I was really hoping to see very low 8s to high 7s. Shifted the car at 6200 rpms Pass 1. R/T .248 60' 2.2364 E/T 8.44 MPH 89.32 (left at 1500 rpm tried to ease into throttle, blew off tires) Pass 2. R/T .438 60' 2.1189 E/T 8.42 MPH 89.43 (left at 2500 slipping the clutch a bit, then full throttle, tires spun at f/t) Pass 3. R/T .270 60' 2.1227 E/T 8.33 MPH 89.57 (left at 3000 slipping the clutch a bit, then eased into it, no spin) Now I didn't do a smoke show burnout as I was a bit afraid to have the car hook to hard and snap an axle. Just did two quick burns then stage. On a positive note I did win all 3-passes. Vette, Mustang, and a ricer
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
05-12-2012, 04:29 PM | #2 |
Drives: 2012 Camaro SS 45th Join Date: Oct 2011
These cars are hard to launch...seems to me you have to fight the computer on the car..i could be wrong ...and i am alot
I had my best 60ft last night @ a 1.957...stock p-zeros at 30 psi. heated them up till i saw smoke...did a dry hop to see if they were gonna hook turned all the nannies off...brake torqued it to 1500 rpm. Usually i'm taking my foot off the brake and pressing the gas pedal about the same time...2.01-2.20 times...this time when i was ready to leave i let off the brake completly and stomped the pedal to the floor like i wanted it to hit pavement..car jumped like never before.didnt get to try this method again as the grudge racing had started before the car cooled enough to try again. reaction .597 .500 is perfect 60 ft 1.957 594 ft 7.829 1/8 et 8.351 1/8 mph 86.20
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh... |
05-12-2012, 05:21 PM | #3 |
Drives: 2011 Convertible SS/RS M6 Join Date: Apr 2012
05-14-2012, 07:03 AM | #4 |
As the runs went on through the night I seemed to be getting a little quicker but still far off from where I think the car should be. Any of you other cammed LS3 cars care to talk a bit on how you are launching?
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot Last edited by newmoon; 05-14-2012 at 07:15 AM. |
05-14-2012, 07:37 AM | #5 |
Drives: 2012 ZL1 Join Date: Dec 2011
Hoosier dr's. Good second gear burnout to get them sticky. Shallow stage. I leave around 3500ish ( I go by sound, not watching the tach) not dumping the clutch but releasing quickly and enjoy the ride. Netted me a slew of 1.7 60's last week. Now I will say the week before the clutch pedal kept sticking to the floor or midway to the floor, so I installed the lingenfelter clutch return spring and problem solved for me. Got to get those dr's hot, I think your soft burnout is most of the problem. Can't be afraid of breaking it
2012 CTF ZL1-stock
2012 ZL1 (sold) JRE 75rwhp kit catless ported lsa TB 11.04 @ 128.35 on hoosier drs and skinnies @ PRP with 1100DA |
05-14-2012, 07:41 AM | #6 | |
2019 GT350 RR
05-14-2012, 07:51 AM | #7 |
No line lock. Just a little slip out of the hole. Basically just releasing the clutch smoothly, but not flat out dumping. It's a little harder on the clutch, but alot easier on the rear! What kind of air pressure are you running in the nitto's? I usually run around 17psi in the dr's when I'm racing.
2012 CTF ZL1-stock
