![]() Drives: 2010 LLT CGM STS Turbo- 500 HP V6 Join Date: Dec 2011
AEM Methonal Kit expectations?
So I am putting a methonal kit on my car to finalize my turbo set up. My car right now on 6 psi is at 373 rwhp. I have a boost regulator valve so im going to probably have it go to 8psi now. What type of rwhp numbers can I expect with this kit? And is the AEM kit a good kit?
Don't Sleep on My V6
Do you have the twin kit or single kit? I have the AEM kit but my controller went bad on me. But it's a complete and good kit.
I have the single rear mount turbo from STS. I just wanna know what gains to expect.
Always bet on Black
Drives: 2011 turbo LS, 2012 f 150, Join Date: Nov 2010
I would say 410 to 420. Depending on tune as well.
boost+v6=me=:)
That is what I had as my old set up and I got 437.rwhp.
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ JUST A LITTLE V6... Try me |
#6 |
Single and twin turbo kits will produce the same numbers roughly. Mostly depends on the size of the turbo's. Only difference will be that a twin will spool faster if the same size. Good luck and keep us posted!
#7 |
On average, how often do you have to refill the tank?
#8 |
If driven daily and in boost about 2-3 weeks if you not to aggressive with you boost. I use 100% meth with the largest injection nozzle and have the low level warning light in my driver side air vent. At the track it cost $4 for a gallon and most shops charge $9 a gallon.
