Old 05-18-2012, 05:18 AM   #1
Wooden Heart
Wooden Heart's Avatar
Drives: 2012 Camaro LT
Underbody Lights Kit
Does anyone have any good solid pictures of their camaro with an underbody light kit installed? I'm torn between getting one. Part of me wants to, then the other part of me says, "Hey man, you're 28, that's way too juvinile."
Any pictures, feedback, recommendations, or opinions are welcome.
Wooden Heart is offline   Reply With Quote
Old 05-18-2012, 05:20 AM   #2
PM Designs
PM Designs's Avatar
Drives: 2011 Camaro, 99 Silverado , 69 C-10
I have it on my car, sorry no pictures though, I like it only use it at night cruise nights though.
PM Designs is offline   Reply With Quote
Old 05-18-2012, 05:50 AM   #3
Wooden Heart
What color, brand, and instillation method? If you don't mind taking the time to reply.
Old 05-18-2012, 06:20 AM   #4
PM Designs
PM Designs's Avatar
7 color kit from Ledunderbody.com. I got the kit for trucks since it had 2 more 24" tubes, which I put one under the hood facing the motor, and ones behind the grill facing the radiator. Installing the tubes wasn't hard at all it came with the needed hardware, although the included zip ties were worthless. Hardest part of install was routing the wires. The control box I mounted near the battery in the trunk (it has a wireless remote to control all the functions) and ran the wire down through a grommet in the bottom of the trunk.
A few tips I can give is if you are doing additional tubes behind the grill and hood like i did is to lay the kit out and arrange the tubes so your wiring can connect to the other tubes correctly, they use telephone style plugs to connect the tubes in series hopefully this makes sense. I did the entire install with the help of a friend and didn't raise the vehicle off the ground however if you want you can raise the vehicle which would make things easier but isn't necessacery.
A few other members have underbody lighting on their cars so I'm sure they will chime in with their tips and possibly installation and finished pictures. YouTube has a few videos of camaros with underbody lighting.
Old 05-18-2012, 06:38 AM   #5
Wooden Heart
Thank you very much.
Old 05-18-2012, 07:41 AM   #6
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
you can look at this thread and get an idea. he has white lights. i've also seen a thread with a black car and orange underbody lights
http://www.camaro5.com/forums/showthread.php?t=220776
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 05-18-2012, 09:35 AM   #7
Wooden Heart
Thanks so much. The wheel lights was something that I never even thought about doing because I figured it would look hideous, but that's not the case at all.
Old 05-19-2012, 02:51 AM   #8
Wooden Heart
Just a quick update. I ordered my 10 pc kit today, it should be in by next Friday. I ordered the 10 pc just in case I ever want to go back and add the last two to the trunk. Thanks again for the input.
Old 05-19-2012, 05:11 AM   #9
CamaroIOM
Drives: IOM
I have lights about to be installed mine. Since I have grill lights,halos and fogs upfront from AAC along with knight rider scanner I got under glow rgb strips from AAC to go along just the sides of the car. I also Have side vents that have lights. I also have the wheel lights coming in rgb. I chose not to put in the back since wheel lights bleed some. All theses can be turned on or off from switches in my armrest from emblem pros. You would not know that one light was on the car unless I wanted them on
CamaroIOM is offline   Reply With Quote
Old 05-19-2012, 09:17 AM   #10
Wooden Heart
Nice, any pics?
neon lights, street glow, underbody kit
