Old 05-22-2012, 07:40 PM   #1
Begformercy167
Drives: One Badass Camaro
Lowering Springs
Hi again everyone ive only posted once on here because theres always been answers for anything ive ever needed but i havent found an answer to this . i have 2010 v6 ls and i just recieved my 20's in the mail today which im ecstatic about and i was looking to put 1 1/4 lowering springs on it. i would like to know if this is even worth doing with the 20's on it and also what should i expect performance wise from doing this option ? thanks
Begformercy167 is offline   Reply With Quote
Old 05-22-2012, 08:23 PM   #2
Infinite-T
Infinite-T's Avatar
Drives: 2011 1LT RS RJT
Just a few quick answers;
Yes, its worth doing! It looks really nice!
Performance wise, if you do just springs (and not bushings, sways, etc.) you will notice the ride is a little stiffer. You will lower your center of gravity so you will have less roll on turns, less upforce from wind under your car, better aerodynamic performance, which will produce less drag. Most of these things you will probably not notice much unless you track your car, but you will feel it at higher speeds.
The best ones in my opinion are these:
http://camaro5.com/forums/showthread.php?t=217226
and that price is pretty good to. Go for it!
Build Thread:http://www.camaro5.com/forums/showthread.php?t=196385
Originally Posted by Synner View Post
If you'd rather drive a civic that eats your soul than a camaro that eats your wallet then thats your choice.
Infinite-T is offline   Reply With Quote
Old 05-30-2012, 01:28 AM   #3
SKANLEZ
SKANLEZ's Avatar
Drives: 2000 Camaro SS
I lowered my car with pedders 1" front and 1.5" rear and I love the look. As for the drive, it corners a lot better and more fun to drive. Car is still comfortable, I live in the Bay Area and our roads are not perfect. Can tell it is a little bit more stiff, but does not bother me at all.
2010 Camaro SS
Mods
Custom Hood
Black Rear Berger Panel
Magna Flow Exhaust
Hurst short shifter
ADM cold air intake
Pedders Drop Springs (1.0/1.5)
Niche Apex Wheels 20x10.5 all around 35+ offset
315/35/20 rear and 275/40/20 front tires
Red Calipers
SKANLEZ is offline   Reply With Quote
Old 05-30-2012, 06:55 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Infinite-T pretty well summed it all up.
Old 05-30-2012, 02:12 PM   #5
Begformercy167
My car is sitting almost 5-6 inches off the ground now because of the rim size so im trying to get back down to where it was factory or a tad bit lower
Old 05-30-2012, 02:16 PM   #6
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
We manufacture a drop spring kit specifically for the V6 that will lower your car about 1.25" from where you're currently sitting. The kit is designed not to drop your Camaro too far and compromise performance or longevity of your factory shocks, but still give you a more aggressive look at handling that you're looking for.
We've got the parts in stock and ready to ship! Drop Springs and Sway Bars are the first two things we recommend modifying on the 5th Gen Camaro. When used together the car will look much better and handle MUCH better than it did from the factory!
Old 05-30-2012, 02:59 PM   #7
uriahnazario
Drives: Camaro in need
Would this work with 22's you think?
uriahnazario is offline   Reply With Quote
Old 06-01-2012, 02:15 AM   #8
SKANLEZ
SKANLEZ's Avatar
I don't see why not. I've seen pictures on here with that drop and they seemed to have no issues with 22" wheels. I would think it would look better with 22" wheels.
2010 Camaro SS
Mods
Custom Hood
Magna Flow Exhaust
Hurst short shifter
ADM cold air intake
Red Calipers
Old 06-01-2012, 04:36 AM   #9
2010SSRSM6
2010SSRSM6's Avatar
Most of us roll around on 20" rims for DD duty, and put 22" rims on for shows. Looks great!
Old 06-05-2012, 09:12 PM   #10
JusticePete
Drives: Camaro Justice
220032 / 220033
220032 / 220035
Today we had the pleasure of working with two Camaro5 and SATX community members. Both are V6 owners. They got The LOOK today. We can see that. The questions are:
  1. Did they get any front end coil pop or any other new noises?
  2. Are the coils secure in the perches for trouble free motoring?
  3. Did they sacrifice ride quality to get the look?
  4. The most important question of all are they pleased with the overall result?
The answers are:
  1. No
  2. Yes
  3. No
  4. Yes
Most companies market lowering coils as 1" drop. That has become the frame in which lowering coils are discussed. If we discuss drop in terms of ride height it is easy for a Camaro owner to determine what their new ride height will be. We measure ride height from the bottom of the wheel rim lip, up through the wheel center to the painted edge of the fender. The vehicle should be on a level surface, the wheels straight, 1/4 tank of fuel and as empty as it was new.
The average ride heights for a Camaro are Front 690mm Rear 700mm
220032 - Pedders 6/8 Front Lowering Coils 657mm with 20" Wheels or 1.3” Drop
220033 - Pedders 6/8 Rear Lowering Coils 660mm with 20" Wheels or 1.5” Drop
220035 - Pedders 6/8 Rear Lowering Coils 675mm with 20" Wheels or 1” Drop
Our Camaros today started with these ride heights.
RACELVR24
LF 692mm RF 690mm
LR 706mm RR 703mm
LSCAMARO
LF 688mm RF 687mm
LR 686mm RR 683mm
They finished the day at these ride heights.
RACELVR24
220032 / 220033
LF 664mm RF 663mm Drop 27.5mm / 1.08” Pedders Stated Height 657mm Difference 6.5mm
LR 665mm RR 664mm Drop 40mm / 1.57” Pedders Stated Height 660mm Difference 4.5mm
LSCAMARO
220032 / 220035
LF664mm RF 664mm Drop 23.5mm / .925” Pedders Stated Height 657mm Difference 7mm
LR 669mm RR 664mm Drop 18mm / .708” Pedders Stated Height 675mm Difference 8.5mm
Pedders Average Deviation Today 6.6mm
Chevrolet Average Deviation Today 5.9mm
We would have preferred to beat GM at this game, but today GM beat us. Well maybe they did.
Variables
V6 vs V8
Alignment
Fuel Load
Exhaust
Mileage
We could improve our accuracy for ride height by separating the OEM average ride height into 6 and 8 cylinder groups as well as our finished ride heights. It may well be this is more important to us than to our clients. We have been in the 5th Gen Camaro market from the beginning and have yet to get a client compliant that their finished ride height was 5mm off. We did not check the alignments before we took the cars apart. After writing this post we should have. Both cars had different fuel levels. Both cars were not empty as new. Both cars had aftermarket exhaust changing the rear weight. Both car had more than 20K.
Let's get down to business. In these two images you can see the OEM upper coil is securely trapped in place against the upper perch.
We used a strut compressor to break down the OEM strut and to Re-assemble the OEM strut with new Pedders coils.
In this series of pictures you can see that the new Pedders coil is well trapped even though the threaded strut top is NOT yet exposed.
When the threads are exposed and the nuts made tight the new Pedders lowering coils are securely trapped in place.
Stacker coils are used to make certain a coil stays in the spring seats when the suspension is at full droop. The black wrap on the coil is there to protect against coil pop or coil ping. When the weight of the car is on the wheels, the upper coils lay one on top of the other. While it is possible to balance one basketball on top of another, it requires extraordinary precision. Stacking coils is not all that different. Using a coil wrap prevents coil pop, just in case the lower spring perch, lower insulator, coil, upper insulator, upper spring perch, silver washer, spring plate bush, gold washer, threaded strut and other variables I am sure I forgot to mention are not all perfect.
These rear coils are under load from the weight of the car. You can see where they touch, but have to imagine where they touch as you drive through a parking lot or down the road.
Pedders does not use multiple stacker coils in the front Camaro struts. Let's go back to basketball stacking, a very difficult task when everything is perfectly still. How hard would it be to keep those basketballs stacked if you were moving left to right and up and down The front struts turn in the Camaro much like the basketballs creating to many opportunities for noise. Pedders front Camaro lowering coils do NOT use stacker coils.
With the OEM struts and Pedders lowering coils installed, we move to bush timing. The rubber bushes in the control arms are bonded to steel ferules. When the suspension arms move up and down, the rubber in the bush twists. It is part of the OEM spring rate calculation. When ride height is changed, the bushes must be timed or relaxed to the new ride height. Timing prevents premature bush wear and allows for even load in the rubber twist as the arms move up and down. In the rear the toe, trailing arm, strut, RLCA, and upper inner bushes need to be relaxed. To do so we loosen the bolts that hold them.
The inner two bolts on both arms.
The toe bolts.
Trailing Arm and Toe Bolts
Upper Inner Bolts
The front virtual pivot suspension has only four total bushes. The LCA inners and the Radius bush outer. Sorry, I don't have a picture of the front LCA inner bolts.
Front Radius / Tension arm Bolts.
The next step is to drive the car with the slightly loose bolts to allow everything to settle and then drive on the alignment rack for the final steps: Tighten everything with the weight of the car on the wheels and alignment.
How did we do?
Pedders Tight Spec Alignment
RACELVR24
Front
Caster LF 6.0 RF 6.0
Camber LF -0.7 RF -0.7
Toe LF 0.00 RF -0.1
Rear
Camber LR -0.5 RR -0.5
Toe LR 0.13 RR 0.11
LSCAMARO
Front
Caster LF 6.6 RF 6.6
Toe LF 0.00 RF -0.00
Rear
Camber LR -0.7 RR -0.8
Toe LR 0.13 RR 0.12
How tight are these alignments? When the wind blew, not a big wind, into the shop the readings would drift. When I say they were perfect just before or after we printed the page our two Camaro owners can verify my statement. The purpose of the day was to demonstrate that V6 Camaros can be lowered without coil noise, coil trap issues or any other issues and not kill trees printing the perfect alignment. We would like to have set the rear cambers to ZERO, but you cannot get from here to there with the OEM alignment bolts. The OEM Rear Camber Eccentrics were literally maxed out. While this will vary from Camaro to Camaro I have yet to see a lowered Camaro get to ZERO rear camber with OE eccentrics.
Front camber is adjusted with a camber screw (bolt) in the knuckle.
There should be a 10mm 1.5 pitch Camber Adjusting Screw in the empty holes above. The Camaro does not ship with them and to my knowledge they are not available as a part. This is a great time to dispel a few myths about Camaro front camber adjustment. The strut clevis bracket is slotted for camber adjustment from the factory. You can see the upper hole is slotted in this picture.
Do NOT use camber adjusting offset bolts on the Camaro
If you want to put them on your Honda or Subie it is up to you. They are not as strong as the OEM clevis bolts and are absolutely necessary on a 5th Gen Camaro. It is in the
This is the correct way to adjust front camber on the 5th Gen. One the alignment machine with the clevis bolts loose turning the camber screw tighter (Righty Tighty, Lefty Loosy) will push the knuckle away from the strut. Loosening the camber screw allows the knuckle to fall in toward the strut.
Your alignment shop may have a T.O.M.C.A.T. Air-Assisted Multiple Camber Adjustment Tool air bag. It fits between the wheel and the strut and works in the same way as the camber screw. Inflate (Righty Tighty) the bag to push the knuckle away from the strut or deflate (lefty Loosy) the bag to allow the knuckle to fall into the strut.
Anyone that tells you different, have them call me
Both Camaros we lowered today are daily drivers. Tire wear is important to both owners. The alignments they left with drive great. Ask them. The alignments we gave them are an excellent balance of tire wear and handling. Alignments should be done at least once a year. Compared to new tires alignments are cheap.
Both Camaros drive great! The owners described the ride as more firm, but smoother. When asked about noises after the test drives both said there were none. Both also were very clear about the improvements in drive quality with the tight spec alignments. Typing about there feelings doesn't say as much as a couple of pictures.
I want to thank both of them for coming out. It was a pleasure meeting both of you. Welcome to the PEDDERS NATION!
Old 06-06-2012, 12:36 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
We just finished up designing and releasing our V6 specific BMR lowering springs which lower the car 1.25". Here are a couple pictures of some of our test cars that we used which show the stance given by our springs. Let me know idf you have any questions or if we can help you out.
