Old 05-24-2012, 11:29 AM   #1
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
SCT Scanner 3416 2010+ CAMARO SS
For sale is a SCT 3416 Tuner for the 2010+ Camaro SS. It has been returned to stock so it is ready to tune your car. It comes in the original packaging with the cables and software. These sell for $399.00. I am selling it for $250.
PM for more details.
The SF3 Power Flash arrives Pre-Loaded with DYNO Proven tune files that INCREASE HORSEPOWER and TORQUE! Programming your vehicle with one of SCT's pre-loaded performance or fuel economy tune files is as easy as 1-2-3. Simply plug the OBDII connector into your vehicle's OBDII port, select the pre-loaded tune file using the simple to navigate menu and within minutes the SF3 programs your vehicle.
  • Increases Horsepower & Torque!
  • Easy to Read On Screen Data Monitoring
    With a HUGE Backlit display, the SCT SF3 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source!
  • Easy to Install & Easy Return To Stock
    The SF3 Power Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock PCM program. Restoring your vehicle to the stock PCM program is as easy as selecting Return to Stock from the device menu.
MRGOODWRENCH3 is offline   Reply With Quote
Old 05-24-2012, 01:10 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
dont these have to be reprogramed once u use them..
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-24-2012, 01:13 PM   #3
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
As long as he took his SCT scanner connected it to his car and re tuned it to stock you should be good to go. Also the 3416 is the model that has preprogrammed tunes for m6 and automatic camaros. This unit will also work well if you give Ted @ Jannetty Racing a call and he can give you an even better tune to upload to your vehicle using this device.
Here is link for further info
http://www.sctflash.com/products.php?PID=7&VID=#3
Go to adustable options
c_LoW29 is offline   Reply With Quote
Old 06-05-2012, 12:13 PM   #4
MRGOODWRENCH3
Still have it for sale. It has been returned to stock so it will work on your Camaro.
Old 06-06-2012, 07:55 AM   #5
bufb45
Drives: 2012 45th Anniversary Camaro
Free bump
bufb45 is offline   Reply With Quote
Old 06-12-2012, 09:11 PM   #6
MRGOODWRENCH3
Great deal on the SCT Tuner. $250
Old 06-13-2012, 08:59 PM   #7
Incider
Incider's Avatar
Drives: 2012 super black SS
Still have tuner?
Incider is offline   Reply With Quote
Old 06-14-2012, 10:58 PM   #8
King Smash
Drives: BLK/Blk 2010 Camaro 2SS
Looking to buy please DM
King Smash is offline   Reply With Quote
Old 06-15-2012, 10:39 AM   #9
MRGOODWRENCH3
Scanner has been sold.
Old 06-15-2012, 10:40 AM   #10
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
nice....
MARINE1991 is offline   Reply With Quote
programmer, sct 3416, sct tuner
