05-27-2012, 10:42 PM | #1 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
Turbo car traction question
My car is a turbo l99 camaro turbonetics kit, BMR full poly subframe bushings BMR trailing arms and toe rods, 1.25 inch pfadt springs car dynoed at 481 hp 491 tq traction wasn't too bad with stock p zeros Never pulled
We added a zl1 fuel pump and also boost gauge and wide band, turned the boost up about a pound Since its done the car is pulling to one side I find myself having to steer to correct at wot it's actually a little scary I expected her to spin not pull to one side. I added tired 315 invos on new rims ( since returned for other reasons ) same issues . My question could it be caused by the need for an alignment ? When the cradle was dropped the car def isn't sitting right since being put back together. Camber is def off can that cause this? Or do I really drag radials ? Any ideas will be greatly appreciated Sorry I'm new to fi cars |
05-27-2012, 10:58 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
Every time you drop the cradle the car should be re-aligned. There is no way to put it back together and have it be where it was. And you really don't need drag radials. I drive my car around in the stock Pirellis and it's fine. Get yourself a good alignment.
05-27-2012, 11:23 PM | #3 |
The Man in Black
Thanks bro hope all is well
05-28-2012, 02:45 AM | #4 |
Drives: 2010 camaro 1ss/rs and 2010 2ss/rs Join Date: Sep 2010
If they dropped subframe your car has to be aligned, even after the lowering kit! no way it can be perfect and yes, that can cause the car to drift, wander, or dogtrack
With love
DirtySilver (2010 camaro 1ss/rs LS3 twin turbo 556whp @6psi, 800+whp @ 18psi) BlackBetty (2010 camaro 2ss/rs L99 boltons 400whp) 2003 Silverado 1500 4x4 quadrasteer 5.3L 2018 Escalade 6.2L CustomDip&Paint LLC. Discount for all Camaro5.com users. |
05-28-2012, 04:31 AM | #5 |
The Man in Black
The car was aligned after springs then aligned after the suspension work. I knew it had to be aligned again just didn't know if that was my issue.
Going to be getting rims again once my situation works out going with a 10.5 or 11 inch rears and 315s I'm hoping that will help the spinning a bit , the spinning doesn't bug me as much the pulling does. The car gets a lot of family use while I don't open her up much with my boys in the car I'd like it be as safe as possible. Thanks for the responses |
05-28-2012, 05:08 AM | #6 |
hey mike..i know how yo.stop the apinning bro...give me the kit and go back to stoxk..and boom no more spinning!!
Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-28-2012, 05:20 AM | #7 | |
The Man in Black
Have fun today bro see you soon |
05-28-2012, 06:07 AM | #8 |
wish u could make it mike!
05-28-2012, 06:38 AM | #9 |
Not only should you have it aligned you should have it weight balanced with you in it. You should get all four corners as close to the same as possible.
05-28-2012, 07:37 AM | #10 |
The Man in Black
Me too Jeff have family stuff
The weight balance idea I hadn't thought of thanks |
05-28-2012, 11:31 AM | #11 | |
Most alignment shops rely on the machine too much and as long as the settings are in the Green Window they don't bother to adjust anything. Where the system will allow up to 1.5 degrees varience in the green window. We do alignments the old fashion way but with a Laser alignment system, setting each specification to a Perfect Number within 1/10 of a degree. The tools are only as good as the guy using them, and I have the Best Suspension tech East of the Mississippi. Now Every Tire has it's limitations on how much power it can handle before breaking lose and spinning, and your clearly overpowering your tires. Ted.
www.jannettyracing.com
05-28-2012, 11:42 AM | #12 |
The Man in Black
Thanks Ted just wish you were a bit closer can you pm a price for an alignment ?
05-28-2012, 12:00 PM | #13 | |
Ted.
05-28-2012, 04:05 PM | #14 |
The Man in Black
Thanks for the info
what tires do you suggest ? |
