Old 05-29-2012, 11:45 PM   #1
the godfather
the godfather's Avatar
Drives: Camaro ZL1 orange
How the shift timing lights works
Hello every one,
I have question about the shift timing lights. It dosn't show on my display, I don't know why. Is there is way to turn it on? Or I'm missing something to do for it to work. Thank you.
By the way my car is manual transmission
2G1F*1EP2*9801242
the godfather is offline   Reply With Quote
Old 05-29-2012, 11:54 PM   #2
16floz470ml
16floz470ml's Avatar
Drives: 2012 ZL1 GLJ MG9 WBP RTQ
It only works when you have the g meter selected and you have to rev it up for the dots to show.
16floz470ml is offline   Reply With Quote
Old 05-30-2012, 12:30 AM   #3
the godfather
Thank you, how you can select the g meter?
2G1F*1EP2*9801242
Old 05-30-2012, 12:50 AM   #4
KKreme15
KKreme15's Avatar
Drives: C6 Z06
press the HUD button
or turn it.
one of those will get you there
KKreme15 is offline   Reply With Quote
Old 05-30-2012, 12:54 AM   #5
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
Press it. Turning it controls the brightness.
ZL1 #612
snapp32e is offline   Reply With Quote
Old 05-30-2012, 08:06 AM   #6
mcalcote
Drives: 2012 ZL1
I also was wondering...I have changed my hud setting to the g-meter and it still will not show the dots at the top?
mcalcote is offline   Reply With Quote
Old 05-30-2012, 08:21 AM   #7
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Are you taking it above 4000 rpms??
htron50 is offline   Reply With Quote
Old 05-30-2012, 09:10 AM   #8
mcalcote
Drives: 2012 ZL1
No I have not made it to the break in of 1500 miles yet
Old 05-30-2012, 10:56 PM   #9
affox83
System Test Engineer
affox83's Avatar
Drives: '12 ZL1 #1011
I could be completely wrong about this...mine is getting tinted and a clear bra put on so I can't look at the manual, but if I remember correctly to get to the HUD screen with the timing lights you need to be in any PTM mode.
affox83 is offline   Reply With Quote
Old 05-30-2012, 10:57 PM   #10
affox83
affox83's Avatar
Yes I actually read the manual...way back when it was first posted on the forums...
Old 05-30-2012, 11:00 PM   #11
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
Shift lights start at 3k in first gear.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 06-05-2012, 03:35 PM   #12
ezleeinfamous
ezleeinfamous's Avatar
Drives: 2012 ZL1
Does the auto w/tap shift have the shift lights?
ezleeinfamous is offline   Reply With Quote
Old 06-05-2012, 05:09 PM   #13
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Nope, just have the G meter on the HUD, and tach out the RPMs. The dots will be faint at first and then brighten up as they close in on the center of the screen.
Pretty fun to play with. Just be careful you will speed up fast!
armysig is offline   Reply With Quote
Old 06-05-2012, 05:44 PM   #14
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
With the M6 and have HUD set to G meter I only see the timing lights in first gear while accelerating quickly.
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
