Old 05-30-2012, 12:42 PM   #1
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Can anyone that owns this give me a review?
As the title says I am considering purchasing this fuse box Cover but I would like to know what you guys that have one have to say about it.
Thanks for the help.
http://autoagenda.com/catalog/2010-c...se-relay-cover
Edit: sorry mods didn't realize i was the general section. Sorry if this should have been in Cosmetics and lighting section.
Old 05-30-2012, 12:45 PM   #2
luckynuts
luckynuts's Avatar
Drives: 10 ABM 1SS/00 Z28 Conv/14 SumWh 2LT
Which cover. You don't have a link?
1 SS/RS 6Sp White Rally Stripes
luckynuts is offline   Reply With Quote
Old 05-30-2012, 12:47 PM   #3
menendez1293
My honest mistake thank you for pointing it out. I am editing the original post now. Thanks again.
Old 05-30-2012, 12:57 PM   #4
luckynuts
luckynuts's Avatar
Can't help you out on that one. I have the carbon fiber cover from Ohio speed. I am sure someone will chime in for you. Good luck.
Old 05-30-2012, 02:00 PM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I have it. Works fine. Just sticks onto top of cover with 3m tape. Mine has been on for about 16 months with zero issues. Mine was free with my custom valve covers. Wouldn't say i'd pay for it but it's fine and painted well.
$70-$120 is insane for what this is. The ONLY way i'd recommend is if you have the matching rotofab covers. All it is is a piece of aluminum painted on the top and held on with 2 pieces of 3m.
Be better off buying their covers when they run a freebie special and taking that item for free.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 05-30-2012, 02:23 PM   #6
menendez1293
Figured it was like that. For 70 bucks I can probably get a pretty nice paint job done or have some fun doing it myself. I'm mainly looking for something to spice up the engine bay in my 2LT that won't break the bank because some of those polished accessories and others like it can go for a lot of money.
Old 05-31-2012, 12:28 AM   #7
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Check out pete's work , the cost is well worth it and great work .. We have a 1LT and it makes the engine bay look great .
http://showstopperaccessories.com/
BIO-HAZARD is offline   Reply With Quote
Old 05-31-2012, 12:39 AM   #8
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
you can do it yourself.. it is so easy.. All you need is adhesion promoter, primer, base color and clear coat. Pick your color which I would guess yellow and apply. I sanded the fuse box with 1500 grit sandpaper. it doesnt do much but still help. then spray 2-3 adhesion promoter coats. Spray 2-3 primer coats. 2-3 base color coats. finally, 2-3 clearcoat coats. and boom. you got urself a great project. buy good products thou. I used duplicolor for my white and I am not very happy about it. You can even use the same materials for the engine cover. just buy green automotive masking tape. the green tape and mask whatever you dont want. and while your at it, hit your intake if you have one. I did all three in the past two days.. Will post pic later. if you need more advice or help, PM me.
Wuiquen is offline   Reply With Quote
